Tunnel is up, line protocol is down
barry-goldberg
I have two cisco routers with tunnels between them.
The keep alive is 3 2 on both of them.
what should i do in order to have line protocol up
Thank you for your help
paolo bevilacqua
Correctly set tunnel source and destination and verify connectivity between said endpoints via:
ping source .
paolo bevilacqua
ping source .
thanks for your reply.
It was my mistake with the access-list.
small mistake
case resolved
