Tunnel Mode IPIP - Huge Blocking Issue
guruprasadr
Level 7
Level 7
Hello Experts,
HO Router:
interface Tunnel1
ip address x.x.x.x x.x.x.x
Tunnel Source x.x.x.x x.x.x.x
Tunnel Destination x.x.x.x x.x.x.x
Tunnel Mode IPIP
end
BO Router:
interface Tunnel70
Tunnel Mode IPIP
end
With the above Configuration, having Tunnel Mode as IPIP the interface IP Address of Tunnel is NOT PINGING. But the Source and Destination Address of the Tunnel is PINGING.
When, i removed the Tunnel Mode IPIP & re-create the Tunnel, the interface IP Address of the Tunnel started PINGING. Atlast, i tried re-adding the Tunnel Mode IPIP it worked even.
Whether after creating any Tunnel will the Router Processor creates some System Generated Routes or how ?
If i am not wrong, any Tunnel by default is GRE mode right ?
Thanks in Advance for your Answers.
Best Regards,
Guru Prasad R
carenas123
Level 5
Level 5
It may be a encapsulation issue or any mode issues between devices verify that one.
