Tunnel MTU
richard.gosling
Hi All,
I have a Router running 12.4
I have configured ip mtu 1300 but when I show int it says 1500 ??
Anyone aware of any bugs?
Terry Cheema
Hi Richard,
Can you check the output of sh ip int tunnel x instead of sh int tunnel?
Does it shows correct or 1500??
If not showing correct, Can you post the output of below:
Sh run int tunnel x
And sh run int for physical interface sourcing the tunnel.
Also sh ip int tunnel x
Terry
Terry Cheema
Hi Richard,
Sh run int tunnel x
Terry
Cheers Terry,
Yep ip int shows the correct MTU
cheers fella
Richard - Glad it helped!
