turbo ACL does not show hit count
S Kumar
I have implemented turbo ACL on Cisco Router 7206 (12.4).
When I execute "show ip access-list 101" some ACE which should have the hit counts does not show. Some lines show the hit count but it is not increasing as fast as it should.
I am missing something?
Amit Goyal
Hi S Kumar,
Is this ACL inbound or outbound?
If it is an outbound ACL and traffic is initiated locally from the router, you will not see hits in ACL.
For any other traffic flow , you must see hits either inbound or outbound. If you don't see it, you must check if traffic is really hitting to the router or not.
-Amit
