Turn logging on for routers?
ViacomOutdoor
I'm trying to turn on logging on our Cisco 837 ADSL routers to populate my syslog server. I have set these up as LAN-to-LAN's which connect to our Cisco 3000 concentrator. I have added the code below to the routers config, but the only time my syslog server will receive anything is when I log off the router via telnet. I want any loggins via telnet logged or login failures logged, what do I need to do?
logging trap debugging
logging facility local4
logging source-interface Ethernet0
logging 192.168.0.1
which syslog server are you using ? Try another facility, e.g. local1...
GP
I'm using local4
I just tried local 1 and it made no difference, the syslog server is made by Orion Solarwinds (7.7) But it does the same with other syslog server, that's just recieving what the router sends to it.
