Turning on NAT-T on Cisco VPN Concentrator fixed an problem, but is it a se
whiteford
Hi, I had a user that wanted to use his (Vodafone) 3G card and his Cisco VNP client. I would connect but he couldn't access any servers until I enabled NAT-T for the VPN Client connections.
What exacly is NAT-T in basic terms? And is turning this on a security risk in any way?
kjmattakat
TAC case K71102938 may help, there are links in the case info that will give you more info.
http://www.ciscotaccc.com/kaidara-advisor/security/showcase?case=K71102938
