Two 2901 routers routing over fiber.
Colby Collier
Level 5
Level 5
Here is a diagram of the connection:
The good:
- Can ping from Holiday 2901 to local lan
- Can ping from P10 2901 to local lan
- Can ping from Holiday 2901 to 10.10.50.2 and 192.168.146.250
- Can ping from P10 2901 to 10.10.50.1 and 192.168.102.250
The bad:
- Cannot ping from Holiday 2901 to anything past P10 interfaces
- Cannot ping from P10 2901 to anything past Holiday interfaces
Knows issues:
- tracert from P10 to 192.168.102.1
Peak10.2901(config)#do tracer 192.168.102.1
Tracing the route to 192.168.102.1
VRF info: (vrf in name/id, vrf out name/id)
  1 10.10.50.1 4 msec 0 msec 0 msec
  2  *
This is coming out and dying on the incorrect interface and I am not sure how to fix.
Peak10.2901(config)#do sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.10.50.0/24 is directly connected, GigabitEthernet0/0
L        10.10.50.2/32 is directly connected, GigabitEthernet0/0
D     192.168.102.0/24 [90/28416] via 10.10.50.1, 00:16:09, GigabitEthernet0/0
      192.168.146.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.146.0/24 is directly connected, GigabitEthernet0/1
L        192.168.146.250/32 is directly connected, GigabitEthernet0/1
holiday.2901#sh ip route
L        10.10.50.1/32 is directly connected, GigabitEthernet0/0
      192.168.102.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.102.0/24 is directly connected, GigabitEthernet0/1
L        192.168.102.250/32 is directly connected, GigabitEthernet0/1
D     192.168.146.0/24 [90/28416] via 10.10.50.2, 00:16:53, GigabitEthernet0/0
holiday.2901#
I have attached configs from both routers as well. Any and all help is much appreciated.
12 Replies 12
John Blakley
On a whim and haven't looked too deep into it, are the default gateways on the devices set to something other than the routers? If so, my first guess is that the device is getting your return traffic and sending it to its default route, but the default doesn't know how to get to the 10.10.50.0/29 or the 192.168.102.250.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
No, there are no default static or gateways of last resort configured.
On PC2824, what's the default gateway configured as?
HTH,
John
It's configured as 192.168.X.1 on the appropriate subnet on each switch.
According to your diagram, if I'm understanding, your default gateway on the PC is pointing to the Fortinet appliance? Does the Fortinet, being on the 192.168.146.1/24 subnet, have a route back to the 192.168.102.x or 10.10.50.x subnet?
HTH,
John
Colby Collier
Level 5
Level 5
Yes it does, what's concerning me is that the trace route isn't getting past the interface of the remote 2901.
mnorwood
Colby,
Some of these things you have done based on our Twitter conversation, but I am listing them anyway for the benefit of others.
1) Plug a workstation/laptop into the switch on one end.
2) Point that workstation to the router as its gateway.
3) From the workstation, try to ping the router's Gi0/1 IP on the far end. ie If your workstation is on the Peak10 side(192.168.146.x), from a command prompt/shell ping 192.168.102.250.
4) If that is successful, ping something else on the 192.168.102.x network other than the router. Hopefully there is a workstation or some other device. You could even try the Fortinet(.1).
5) Post the results of "show ip arp" from both routers.
Matthew
From a workstation on the 192.168.102.x subnet a ping to ge0/1(192.168.146.250) was successful. Pings to the switch on the opposite subnet (192.168.146.249) was unsuccessful.
holiday.2901#sh ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.10.50.1              -   6c20.56a3.1c00  ARPA   GigabitEthernet0/0
Internet  10.10.50.2             34   6c20.56b5.58c8  ARPA   GigabitEthernet0/0
Internet  192.168.102.1           0   0009.0f27.39a6  ARPA   GigabitEthernet0/1
Internet  192.168.102.2           0   0024.e850.8563  ARPA   GigabitEthernet0/1
Internet  192.168.102.3           0   0011.43fc.f10a  ARPA   GigabitEthernet0/1
Internet  192.168.102.15        221   0017.c590.c4b2  ARPA   GigabitEthernet0/1
Internet  192.168.102.95          4   d067.e591.95e0  ARPA   GigabitEthernet0/1
Internet  192.168.102.113         0   d067.e515.8bce  ARPA   GigabitEthernet0/1
Internet  192.168.102.163         0   0023.ae70.adbe  ARPA   GigabitEthernet0/1
Internet  192.168.102.169         0   0025.64c7.df74  ARPA   GigabitEthernet0/1
Internet  192.168.102.173         0   d4be.d9d3.0eb1  ARPA   GigabitEthernet0/1
Internet  192.168.102.250         -   6c20.56a3.1c01  ARPA   GigabitEthernet0/1
holiday.2901#
Peak10.2901#sh ip arp
Internet  10.10.50.1             27   6c20.56a3.1c00  ARPA   GigabitEthernet0/0
Internet  10.10.50.2              -   6c20.56b5.58c8  ARPA   GigabitEthernet0/0
Internet  192.168.146.249        13   d067.e5b0.6732  ARPA   GigabitEthernet0/1
Internet  192.168.146.250         -   6c20.56b5.58c9  ARPA   GigabitEthernet0/1
Peak10.2901#
From the P10 router, can you ping the workstation on the 102 subnet at Holiday?
Yes I can, but ping to other hosts (switch, fortinet, other servers) are failing. The .173 is the host that I ran the ping from in the previous reply.
Peak10.2901#ping 192.168.102.173
Sending 5, 100-byte ICMP Echos to 192.168.102.173, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Sending 5, 100-byte ICMP Echos to 192.168.102.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Peak10.2901#ping 192.168.102.95
Sending 5, 100-byte ICMP Echos to 192.168.102.95, timeout is 2 seconds:
Peak10.2901#
Colby Collier
Level 5
Level 5
This will probably be relevant also....Both 2901 routers and the fiber are a new install as of today. All hosts on the 192.168.102.X subnet are configured with a default gateway of 192.168.102.1 with the exception of the host that I have been running the pings with.
Our end goal here is (once the setup is complete) have all traffic destined for the 192.168.146.X subnet route over the fiber, everything else route out .1
Point everything on both ends to the router as their default gateway. Either 192.168.102.250 or 192.168.146.250, depending on which location the systems reside. The 2901 routers will also need to have a default route pointing to the Fortinet(.1). As much as I hate static routes, you'll want to use one for the 0.0.0.0 route pointing to the Fortinet. Since it is a managed firewall, getting someone to spin up OSPF might take awhile, and if you are replacing those boxes with ASA's, it probably isn't worth the trouble for the time being. Plus, you would also need to spin up OSPF on your routers to avoid having to redistribute. On a network this small, it would be easier to run OSPF if you were peering with the Fortinet boxes.
I suspect the Fortinet boxes are not routing traffic to the 2901 router from the end hosts because they have no route for the subnets across the link.
