I have a Cisco 870Va router. There are two WAN connections from different ISPs. I need to create a LAN for each connection. Both will have their own DHCP server and each will use a different WAN. So LAN1 will use WAN1 and vice versa. Where I am stuck is the route. I can only do ip route 0.0.0.0 0.0.0.0 1.2.3.4 for one WAN only. How do you do it when you have two WANs?
Solved! Go to Solution.
Hi @Frank Sinatra ,
Check this similar discussion of the community, maybe can guide you:
https://community.cisco.com/t5/routing/two-isp-two-networks-one-router/td-p/2189915
You can use a can SLA and/or AD (administrative distance) for it, that you will have a Loadbalance between your wans.
Check it for SLA: https://community.cisco.com/t5/switching/ip-sla/td-p/3014987
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/813-cisco-router-ipsla-basic.html
For AD you can do like it:
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 0.0.0.0 0.0.0.0 192.168.2.1 10
https://audacity.onl/ https://findmyiphone.onl/ https://origin.onl/
Hi @Frank Sinatra ,
