Two devices communicate via WiFi router
ruffysmith
Closed. This question is off-topic. It is not currently accepting answers.
NE is a site for to ask and provide answers about professionally managed networks in a business environment. Your question falls outside the areas our community decided are on topic. Please visit the help center for more details. If you disagree with this closure, please ask on Network Engineering Meta.
Closed 20 hours ago.
Hello I need support to solve next problem and this is situation:
Pc has Wifi adapter with static IP 192.168.1.115 and python script sends UDP data to w5500 which is connected via ethernet cable to LAN port of router. W5500 has IP 192.168.0.8, port 8888 for sending UDP packets, subnet mask 255.255.255.0 and gatway 192.168.1.1. Router (ZXHN H168N V3.1) is on 192.168.1.1. Static routing has next config Entry Name wiz WAN Interface HSI Network Address 192.168.0.0 Subnet Mask 255.255.255.0 Gateway 192.168.1.1
I can get UDP data from w5500 but when I send data from Pc to w5500 I can't get it (Wireshark show correct packets and data). Does anybody can give me hint how I can solve this?
0 Replies 0
