two group of prefix-set have the same effect in ASR9K?
wfqk
Level 5
Level 5
Hi there are two group of prefix-set as below. Do you think the two group have the same effect in ASR9K?
Thank you
prefix-set ABC_V6
2222:1111:::/32 le 128
2222:1111::/32 le 64
prefix-set ABC_V6
Julio E. Moisa
2222:1111::/32 le 64  this prefix is included into 2222:1111:::/32 le 128
So you prefix just could be:
prefix-set ABC_V6
it will check the first 32 bits of the prefix 2222:1111::  and the le 128 means the subnet mask is equal or less than 128.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
