Two IP NAT outside interfaces
I'm trying to get what I imagine is actually something quite easy but as I've never done it I'm having some issues.
Basically I have a setup as below:
interface GigabitEthernet0/0
ip address 8.8.8.8 255.255.255.252
ip nat outside
crypto map vpn
interface GigabitEthernet0/1
ip address 172.17.1.1 255.255.255.0
ip nat inside
interface FastEthernet0/0/0
ip address 172.17.2.1 255.255.255.0
ip nat inside
ip local pool vpnpool 192.168.5.1 192.168.5.100
ip nat inside source route-map nonat interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 8.8.8.7
!1
ip route 172.17.4.0 255.255.255.0 172.17.1.250
ip route 172.22.223.97 255.255.255.255 172.17.1.240
ip route 172.22.223.98 255.255.255.255 172.17.1.240
ip route 172.22.223.101 255.255.255.255 172.17.1.240
ip access-list extended VPN-Traffic
permit ip 172.17.1.0 0.0.0.255 192.168.5.0 0.0.0.255
permit ip 172.17.2.0 0.0.0.255 192.168.5.0 0.0.0.255
ip access-list extended nonat
permit ip 172.17.1.0 0.0.0.255 any
permit ip 172.17.2.0 0.0.0.255 any
deny   ip 172.17.1.0 0.0.0.255 192.168.5.0 0.0.0.255
deny   ip 172.17.2.0 0.0.0.255 192.168.5.0 0.0.0.255
route-map nonat permit 10
match ip address nonat
I am adding an extra interface which connects to an extra router. The new interface will have an IP address of say "10.10.10.2 255.255.255.0".
What I need to happen is if any of the current internal ranges or the VPNpool client range goes to a device out of that interface then it get's natted out of the "10.10.10.2/24" range.
So all the below:
172.17.1.0/24
172.17.2.0/24
192.168.5.0/24
Should get natted to 10.10.10.2 if they need to go to an IP out of the new interface.
Below is what I thought I should add but it didn't work:
ip nat inside source route-map nonat2 interface FastEthernet0/1/0 overload
permit ip 10.10.10.0 0.0.0.255 192.168.5.0 0.0.0.255
ip access-list extended nonat2
permit ip 172.17.1.0 0.0.0.255 10.10.10.0 0.0.0.255
permit ip 172.17.2.0 0.0.0.255 10.10.10.0 0.0.0.255
permit ip 172.17.4.0 0.0.0.255 10.10.10.0 0.0.0.255
permit ip 172.22.223.0 0.0.0.255 10.10.10.0 0.0.0.255
permit ip 10.10.10.0 0.0.0.255 any
route-map nonat2 permit 15
match ip address nonat2
Thanks in advance
2 Accepted Solutions
patrick.preuss
Hi Andrew
you might miss a thing:-) Please try to figure out what dession for nat is taken.
Please have a look into you acls and your route maps
route-map nonat states:
route-map nonat2 states:
so try a debug ip nat and look what nat desision is made.
Form my point of view
route-map nonat is matched.
Try to add a second match in you routemap to make the dessision process more specific. You can add a match to the interface. Because the router allready knows where to exit the packet. https://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
match interface         Match first hop interface of route
match ip next-hop     Match next-hop address of route
match interface GigabitEthernet0/0
match interface FastEthernet 0/1/0
Patrick
patrick.preuss
Andrew
is your problem solved ?
Please assign point ;-)
Patrick
patrick.preuss
Hi Andrew
Patrick
patrick.preuss
Andrew
Patrick
It is indeed thanks Patrick but I actually found the solution via someone else on these forums via a historic search.
The answer is pretty much the same as what you have provided however so points your way
Hi Andrew
you are welcome and please. As allways nothing new.
Tanks for the points ..
