Two link failover
rockey
hi all
i have two p2p link with same ip subnet.
one link is in routing mode i.e static routing
second link is in vlan mode
I want to use ip sla / tracking between in this two link then auto failover happend
plz suggest me how to configure this.
MANI .P
Hi , Second link is to make a routing mode &  Do the PBR  for fail over configuration .
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/861-cisco-router-pbr-ipsla-auto-redirect.html
Ganesh Hariharan
hi all
 Hi ,
Make the secondary link as also point to point link and configure IP SLA based on below information.
IP SLA tracking on dual link
Hope it Helps..
-GI
Rate if it Helps
