11-04-2015 10:50 AM - edited 03-05-2019 02:40 AM
Hi Guys
I want to balance traffic using two links.
What is the best practice for balance traffic ???
I use routing EIGRP and Tunnels GRE,
I try with EIGRP LEAK but I do not is the best option.
Regards.
Solved! Go to Solution.
11-18-2015 08:32 PM
Hi Francisco,
PFR is always a best option but since it is difficult to implemet, you may end up with nothing. So i would recommend you to implement PBR. Below is the link whic can help you.
http://www.cisco.com/c/en/us/support/docs/ip/ip-routed-protocols/48003-pbrtracking.html
Above link describes the steps of applying PBR using track mechanism to check the status of ISP link. If ISP1 is good keep sending traffic to ISP1 for all traffic matched in ACL 10. If ISP1 fails, traffic will start moving over ISP2. Similarly you can add one more statement in route-map matching ACL 20 and preferred ISP2 for this and ISP1 as
Interface <LAN interface>
ip policy route-map alphaback up.
route-map alpha permit 10
match ip address 10
set ip next-hop verify-availability <IP of ISP1> track 123
set ip next-hop verify-availability <IP of ISP2> track 124
route-map alpha permit 20
match ip address 20
ip access-list standard 10
permit ip <permit subnet which you want to pass via ISP1>
ip access-list standard 20
permit ip <permit subnet which you want to pass via ISP2>
You can also refer to the discussion on below link for the same requirement with 3xISP links.
https://supportforums.cisco.com/discussion/12391981/bgp-redundancy
-Amit
11-04-2015 11:32 AM
Hello
load sharing in eigrp can be either equal or unequal
Can you provide additional information regards your topology and exactly what you wish to achieve
res
Paul
11-04-2015 12:20 PM
I want is to balance the traffic, use both links.
Use the both IPS.
11-04-2015 12:39 PM
Hello
unfortunately this isn't enough information to provide a solution
Can you share a topology of your network how it is presently and the current traffic path from your clients
res
Paul
11-04-2015 01:09 PM
Yes, attach a similar topology.
configuration
conf t
router eigrp 1
network 192.168.0.0 0.0.255.255 -> LAN
passive-interface default
no passive-interface Tunnel27
no passive-interface Tunnel28
exit
interface tunnel 27
Description *** ISP_1 *** -> LAYER 2 bandwidth 10000
ip address 10.10.5.2 255.255.255.252
load-interval 30
delay 1
keepalive 10 3
tunnel source 172.16.0.90
tunnel destination 172.16.0.89
interface tunnel 28
description *** ISP_2 *** ->LAYER 3
bandwidth 5000
ip address 10.9.1.2 255.255.255.252
load-interval 30
delay 1
keepalive 10 3
tunnel source 172.20.5.246
tunnel destination 10.10.1.50
I want to pass traffic for both tunnel
11-05-2015 12:01 AM
Hi Francisco,
You can use either PBR (Simplest method) or make use of PFR which is the smartest way (but little tough to implement) of doing load balancing.
-Amit
11-18-2015 02:25 PM
Hi Amit
Do you have example configuration of both protocols?
What protocol are you recommend?
11-18-2015 08:32 PM
Hi Francisco,
match ip address 10
match ip address 20
-Amit
11-06-2015 06:34 AM
Hello
Are those Bw and Delay values historical or have you set them to try and acheive LB?
Can you share
Sh ip route eigrp
sh ip eigrp topology
Applying equel LB to a current unequal LB senario can be done -
Example:
Sh ip route x.x.x.x.
sh ip eigrp topology x.x.x.x.| in Composite
Of the two entries in the eigrp topology table for this route you will see the coompostic metrics , these need to be divided
Composite metric is (409600/128256), Route is Internal
Composite metric is (5273600/128256), Route is Internal
5273600 / 409600 - 12.875 - Round this up the nearest full value = 13
router eigrp xxx
varience 13
sh ip route x.x.x.x | in traffic
Route metric is 409600, traffic share count is 240
Route metric is 5273600, traffic share count is 19
290 / 19 = 12.6
sh ip route eigrp x.x.x.x
D x.x.x.x [90/409600] via 10.1.13.3, 00:01:55, FastEthernet0/1
[90/5273600] via 10.1.12.2, 00:01:55, FastEthernet0/0
res
Paul
11-18-2015 08:22 AM
If the bandwight is different I can configure PRB??
Do you kneo CEF es great option or not?
11-18-2015 08:51 AM
Hello
you can do for eigrp unequal load sharing also
PLease share your
Show ip eigrp topology
res
paul
11-06-2015 02:22 AM
PBR is the best option ....
11-06-2015 06:02 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If your two paths are equal bandwidth, or close to being equal, EIGRP ECMP would be an easy solution.
If your two paths vary much in bandwidth, EIGRP support unequal path load balancing, although another poster, in other posts, says EIGRP doesn't do it very efficiently. (I.e. it might drive up CPU.) This is also rather easy to config.
If your devices support PfR with PIRO, it might be used to do dynamic load balancing, and it can support both equal or unequal bandwidth paths. This is the most optimal solution but requires learning a whole new technology.
As others have already noted, you could also use PBR, but it's often a bear to maintain, and you need to be careful with your config to deal with a path failure.
