Two publics IPs, one ADSL interface
cesar.sierra
I've two public IPs from my ISP. I'd like to implement them in a router Cisco 1701. First IP works OK, but the secondary doesn't. This is the WAN interface config:
interface ATM0.1 point-to-point
description $FW_OUTSIDE$
ip address 80.44.47.220 255.255.255.0 secondary
ip address 223.58.221.212 255.255.255.0
ip access-group 105 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
pvc 8/32
encapsulation aal5snap
I don't know if this is the correct config, or maybe I have to define a ATM0.2 interface
Any ideas? Thanks
globalnettech
Level 5
Level 5
are both public IP addresses from the same provider ? Can you post the full configuration of your router ? Also, do you want to have your internal addresses translated to both public IP addresses ?
GNT
Yes, both public IP addresses are from the same provider (same VPI/VCI)
I bought two public IPs due to I've two Internet services (Citrix and secure webmail) running on the same port and different internal IPs.
Internet is reached without problems from internal addresses, and I've redirected both public IPs to internal IPs, but only one public IP (the primary) works
Attached to this post is the router config
Cesar
