Two questions regarding memory on ISR 4321 routers
Can_networking
I am expanding the hardware on a ISR 4321 router.
1) Question: What is the maximum memory allowed in the DRAM socket ?
I am seeing conflicting answers:
  • The specifications site says a 4GB DRAM maximum in the memory socket.
  • One white paper says the router can support 4-12 GB total, implying that 4GB or 8GB DRAM can be used in the memory socket
2) Question: Is there anything special about DRAM used in the 4321 ?
(e.g, I know Cisco routers & switches cannot use generic SFPs, you need Cisco branded SFPs)
My understanding is a generic (non-Cisco) 4GB (or 8GB), DDR3, ECC, 1600 MHz should work.
I already tried a 1333 MHz part and got an error message on boot-up. I assume this is to be expected. I am going to try a 1600 MHz later today.
Leo Laohoo
For ths 4321, Maximum DRAM is 8 Gb.
Only use Cisco-branded memory or else you'll have grief.
Leo,
You are absolutely right, when I used Cisco branded DRAM on my unit, the expansion memory was recognized and the bootup error message went away.
