Two tunnels, two different mtu values, no OSPF adjacency
warren.sullivan
Hi all,
Well this is an interesting one, i have a tunnel configured between two 2921 routers that used to work just fine, we had an management access issue on one of the routers and it had to be rebooted, all looked fine until one of OSPF adjacencies didn't come up, the one across the tunnel in question, ran a dubug and saw;
Apr 10 2015 09:58:30.319 AEST: OSPF-100 ADJ   Tu100: Nbr 10.0.6.12 has larger interface MTU
OK, so i check both ends of the tunnel, MTU different;
bne-rt01#sh int tunn 100
Tunnel100 is up, line protocol is up
  Hardware is Tunnel
  Internet address is 10.0.3.62/30
  MTU 17874 bytes, BW 204800 Kbit/sec, DLY 50000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 10.255.255.1 (GigabitEthernet0/1/0), destination 10.255.255.5
   Tunnel Subblocks:
      src-track:
         Tunnel100 source tracking subblock associated with GigabitEthernet0/1/0
          Set of tunnels with source GigabitEthernet0/1/0, 2 members (includes iterators), on interface <OK>
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 1434 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "PTQ-IPSEC-PROFILE-2")
  Last input 00:00:02, output never, output hang never
  Last clearing of "show interface" counters 27w0d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 103048
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     2526404 packets input, 944901813 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     2701610 packets output, 706777352 bytes, 0 underruns
     0 unknown protocol drops
brn-rt01#sh int tunn 100
  Hardware is Tunnel
  Description: PIPE_Backup
  Internet address is 10.0.3.61/30
  MTU 17866 bytes, BW 204800 Kbit/sec, DLY 50000 usec,
  Keepalive not set
  Tunnel source 10.255.255.5 (GigabitEthernet0/1/0), destination 10.255.255.1
   Tunnel Subblocks:
      src-track:
  Tunnel transport MTU 1426 bytes
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 01:04:19
  5 minute input rate 3000 bits/sec, 1 packets/sec
     1723 packets input, 1069064 bytes, 0 no buffer
     962 packets output, 91128 bytes, 0 underruns
checked the IP MTU, different;
bne-rt01#sh ip int tunn 100
  Broadcast address is 255.255.255.255
  Address determined by setup command
  MTU is 1434 bytes
brn-rt01#sh ip int tunn 100
  Address determined by non-volatile memory
  MTU is 1426 bytes
Checked the source interfaces MTU, same;
bne-rt01#sh int gi0/1/0
GigabitEthernet0/1/0 is up, line protocol is up
  Hardware is EHWIC-1GE-SFP-CU, address is 442b.03e5.8870 (bia 442b.03e5.8870)
  Description: OPTUS IPVPN WAN
  Internet address is 10.255.255.1/30
  MTU 1500 bytes, BW 204800 Kbit/sec, DLY 10 usec,
brn-rt01#sh int gi0/1/0
  Hardware is EHWIC-1GE-SFP-CU, address is 5057.a819.3620 (bia 5057.a819.3620)
  Internet address is 10.255.255.5/30
Checked IP MTU on source, same;
bne-rt01#sh ip int gi0/1/0
  MTU is 1500 bytes
brn-rt01#sh ip int gi0/1/0
  MTU is 1500 bytes
below is the configuration of the physical source;
bne-rt01#sh run int gi0/1/0
Building configuration...
Current configuration : 209 bytes
interface GigabitEthernet0/1/0
 description OPTUS IPVPN WAN
 bandwidth 204800
 ip address 10.255.255.1 255.255.255.252
 ip traffic-export apply WAN-Traffic-capture size 1000000
 duplex auto
 speed auto
end
brn-rt01#sh run int gi0/1/0
 bandwidth 204800
 ip address 10.255.255.5 255.255.255.252
 duplex full
 speed 1000
end
below is the configuration of the tunnel interfaces;
bne-rt01#sh run int tunn 100
Current configuration : 245 bytes
interface Tunnel100
 bandwidth 204800
 ip address 10.0.3.62 255.255.255.252
 ip flow ingress
 ip flow egress
 tunnel source GigabitEthernet0/1/0
 tunnel destination 10.255.255.5
 tunnel protection ipsec profile PTQ-IPSEC-PROFILE-2 shared
end
brn-rt01#sh run int tunn 100
Current configuration : 270 bytes
interface Tunnel100
 description PIPE_Backup
 bandwidth 204800
 ip address 10.0.3.61 255.255.255.252
 ip flow ingress
 ip flow egress
 tunnel destination 10.255.255.1
end
To be honest i'm a bit lost as to the reason, any ideas guys?
regards
warren
Hello
has anything been physically changed regards connectivity between these routers?
you can negate the ospf mtu check by appling
int x/x
ip ospf mtu-ignore
res
paul
Kind Regards
Paul
Peter Paluch
Hi Warren,
According to this thread:
https://supportforums.cisco.com/discussion/11305311/understanding-mtu-given-gre-tunnel
the first displayed MTU of over 17000 bytes (let's call it simply tunnel MTU as opposed to the tunnel transport MTU) is computed from platform buffer sizes. I suspect that the memory-size iomem command may have something to do with this. Without this command, the router decides how much memory to set aside for packet buffers depending on the installed interfaces and network modules - and of course, based on the IOS version as well, as this automatic IOMEM sizing is performed by the IOS when booting, and different IOSes may do things differently. With this command configured, a fixed percentage of RAM can be reserved. Could something of this have changed between reboots - a different IOS version, perhaps, or adding/removal of this command, or change in installed network modules and interfaces?
Nonetheless, the difference between the tunnel MTUs (8 bytes) seems to correspond to the difference between the tunnel transport MTUs and IP MTUs. Somehow, the change in the tunnel MTU could have affected the resulting tunnel transport MTU.
Yet another question is whether the IPsec policy (transform set, key sizes, etc.) is identical to the IPsec policy before the reload. If my memory serves me, in IPsec, if two peers have identical but differently ordered ISAKMP and IPsec policies, the resulting IPsec operation depends on who first started the ISAKMP negotiation (the idea is: the initiator of the IPsec tunnel proposes all its ISAKMP, and afterwards, all its IPsec policies, and the target of the IPsec tunnel chooses the first one that matches one of its policies). If by any chance the configuration of ISAKMP policies, IPsec transform sets, etc. is not letter-identical on this router and the other endpoint, it is possible that the router now operates the IPsec differently than before the reload, which could affect the overall overhead, and thereby the tunnel transport MTU as well.
In any case, with tunnels, it is my strong recommendation to configure a conservatively low MTU manually. With IPsec-protected GRE tunnels over IPv4, the recommended manual MTU is 1400 and so the TCP MSS should be clamped to 1360. The recommendation for MTU of 1400 is taken from this document:
http://www.cisco.com/c/en/us/support/docs/ip/generic-routing-encapsulation-gre/25885-pmtud-ipfrag.html#t16
I would personally suggest configuring the MTU manually on all your tunnels to 1400. This will both provide for a reasonable reserve in case your own ISP uses some additional overhead to carry your packets, and at the same time, it will prevent your routers from automagically (and obscurely) changing your tunnel transport MTUs between restarts.
Best regards,
Peter
