UDP flooding on L3 switch
prasad.patkar
We are flooding udp broadcast using routers ( ip helper-address and directed broadcast), we have created tunnels between both the segment of the firewall.
We want to replace both the existing lan segment with layer 3 switches on DMS with 4503 and in the lan 3750, and create the tunnel for both hsrp so as to achive redundancy.
Pl help me in configuring tunnel between both the HSRP and flood the udp traffic using the tunnel. Attached ppt for u r reference, also want to know how can we measure the bw of the flooded traffic on LAN.
Prasad
0 Replies 0
