UDP Port Forward Problem on Cisco 1921
rvidrascu
Hi all,
I have some problems with my Cisco 1921 router when trying to forward UDP ports. There are 2 network interfaces:
- gi0/0 [connected to the internet]
- gi0/1 [connected to the private network]
The router is suposed to do NAT and to forward TCP port 80, TCP port 1720 and UDP port 1719. The TCP ports are forwarded corectly, the problem is on UDP - router replies with ICMP destination port unreachable when internet users try to reach the inside "server". Same configuration was verified on one Cisco 892 Router and no problem was found [UDP port was correctly redirected].
Here is the config:
version 15.1
hostname R2-1921
boot-start-marker
boot system usbflash0 c1900-universalk9-mz.SPA.151-2.T2.bin
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
interface GigabitEthernet0/0
ip address 195.90.xxx.yyy 255.255.255.128
ip nat enable
duplex auto
speed auto
interface GigabitEthernet0/1
ip nat enable
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat source list 10 interface GigabitEthernet0/0 overload
ip nat source static tcp 192.168.1.205 80 interface GigabitEthernet0/0 80
ip nat source static udp 192.168.1.205 1719 interface GigabitEthernet0/0 1719
ip nat source static tcp 192.168.1.205 1720 interface GigabitEthernet0/0 1720
ip route 0.0.0.0 0.0.0.0 195.90.xxx.yyy
access-list 10 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
15 Replies 15
rvidrascu
Problem fixed running 2 commands:
- no ip nat service ras
- no ip nat service H225
