Unable to access Router Interface Public IP address from LAN
jamaludeen_s
I have router with two DSL Internet connection  (ISP-1 , ISP-2) ISP-1 with Static IP address whereas ISP-2 with Dynamic IP address.
ISP-1 is dedicated for Exchange server traffic (NAT is configured on Router to access Exchange server from outside- Internet)
ISP-2 is used for employees Internet access.
From Internet users are able to access Exchange server.
Users from office LAN access the Exchange server using its public IP address (ISP-1 Static IP) and it’s not working, because when the traffic reach the router the public IP address is router Interface IP address.
Also we don’t have registered Domain to play around with DNS settings.
I tried configuring route-map it doesn't work since the destiantion IP address is there in routing table..not sure about vrf
Is there any way to make it work.
Thanks in advance
Jamal
mvsheik123
Level 7
Level 7
Hi Jamal,
You may need to look into solution 'DNS rewrite/doctoring (with IP- as no DNS names here). Pls check the below link-
https://supportforums.cisco.com/thread/2003063
hth
MS
mvsheik123
Level 7
Level 7
Hi Jamal,
hth
MS
Thanks a lot MS..I will go with Option 2.
Jamal
