Unable to activate Capture on Cat4k
CiscoBrownBelt
Level 6
Level 6
Keep getting "Unable to deactivate Capture" no matter what syntex I try. For most part I do this:
 Create a capture called 'PCAP', and capture packets in both directions on Gi0/0/1
Router# monitor capture PCAP interface GigabitEthernet 0/0/1 both
! Capture any IPv4 packets going to host 8.8.8.8
Router# monitor capture PCAP match ipv4 any 8.8.8.8/32
! Start the packet capture
Router# monitor capture PCAP start
or monitor capture TESTMONCAP buffer size 100 access-list TEST_ACL inteface vlan 10 (or g2, etc.) both
ip access list standard TEST_ACL
permit 10.1.1.1 any
 Any help?
pman
what about the "monitor capture PCAP stop" command?
You can attach an output of the following commands:
show monitor capture PCAP
show monitor capture PCAP buffer brief
Did you try to set the file path as well?
4500TEST#monitor capture MYCAP interface g2/26 both
4500TEST#monitor capture file bootflash:MYCAP.pcap
4500TEST#monitor capture MYCAP match any start
I have attached links for reference:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-4500-series-switches/116470-configure-product-00.html
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-9-0E/15-25E/configuration/guide/xe-390-configuration/wireshrk.html
no, stopping capture does not work either.
monitor capture file bootflash:MYCAP.pcap (File is not option; must specify name of capture first, I have already deleted everything and  reconfigred though)
I am not able to post on here.
--> unable to deactivate capture
Did you try:
no monitor capture PCAP file
or reboot the switch ?
Yes i have tried deleting and reconfiguring.
No can't just reboot right now.
