Unable to Capture outbound packets on WS - Cisco IR807
networkENG12
Hi All,
I'm struggling to capture outbound packets via FastEth1 on Wireshark.
I have set up a base configuration to allow connection upstream, IPSLA icmp-echo to sed upstream node is working fine. No ACL's applied and static route added.
However I can't see these outbound packets on the capture.  Can only see Ethernet II.
FastEthernet1 counters are shown below - output packets are going up but no 5 minute output rate.
Plus also seeing lots of unknown protocol drops - what could these be? What debug command can i use to show these?
Putting up on this board as there isn't much help on the web.
Can anyone help to dissect/or has faced this problem too?
FastEthernet1 is up, line protocol is up
Hardware is PQ3_TSEC, address is b0c5.3cc7.ceea (bia b0c5.3cc7.ceea)
Internet address is 192.168.71.20/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d17h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
16192 packets input, 3791491 bytes
Received 7781 broadcasts (0 IP multicasts)
0 watchdog
37723 packets output, 12714066 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
5003 unknown protocol drops
3 lost carrier, 0 no carrier
0 Replies 0
