Unable to change my username and password on Cisco 2800
hutto.txed.net
I have tried to change the username and password using the following procedure but when I do so and reboot the router and try to login using the new userid and password it says Authentication failed. What am I doing wrong?
Complete these steps in order to recover your password:
  1. Shut down the router.
  2. Remove the compact flash that is at the back of the router.
  3. Power on the router.
  4. Once the Rommon1> prompt appears, enter this command:
    confreg 0x2142
  5. Insert the compact flash.
  6. Type reset.
  7. When you are prompted to enter the initial configuration, type No, and press Enter.
  8. At the Router> prompt, type enable.
  9. At the Router# prompt, enter the configure memory command, and press Enter in order to copy the startup configuration to the running configuration.
  10. Use the config t command in order to enter global configuration mode.
  11. Use this command in order to create a new user name and password:
    router(config)#username cisco privilege 15 password
              cisco
  12. Use this command in order to change the boot statement:
    config-register
              0x2102
  13. Use this command in order to save the configuration:
    write
          memory
  14. Reload the router, and then use the new user name and password to log in to the router.
16 Replies 16
cadet alain
At step nine copy the config and post here.
Regards.
Alain
Current configuration : 3913 bytes
version 12.4
service timestamps debug datetime msec localtime show-timezone year
service timestamps log datetime msec localtime show-timezone year
service password-encryption
hostname TECH.SRST
boot-start-marker
boot-end-marker
logging buffered 16384 debugging
enable secret 5 $1$0rfp$3tUcm5rbW0rEGcu4MQlRz0
aaa new-model
aaa authentication login default group radius local line enable
aaa authentication enable default group radius enable line
aaa authorization console
aaa authorization exec default group radius local if-authenticated
aaa accounting suppress null-username
aaa accounting exec default start-stop group radius
aaa accounting system default start-stop group radius
aaa session-id common
clock timezone CST -6
clock summer-time CDT recurring
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
ip cef
no ip domain lookup
ip domain name hutto.txed.net
isdn switch-type primary-ni
trunk group  POTS
max-calls any 2
hunt-scheme sequential
--More--                           voice-card 0
no dspfarm
voice translation-rule 1
rule 1 reject /5555555555/
voice translation-profile BLOCK
translate calling 1
username calence privilege 15 secret 5 $1$iBGF$yYDT.QN1mTF7mENE3pyk7.
username admin privilege 15 secret 5 $1$jttL$6afcdsWpWGhmjPpz5DJyL0
username cisco privilege 15 password 7 110A1016141D
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
description 60.IPZX.351598..CRTX
interface GigabitEthernet0/0
ip address 10.55.100.2 255.255.254.0
shutdown
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.55.100.2
interface GigabitEthernet0/1
--More--                            no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
no logging event link-status
isdn incoming-voice voice
no cdp enable
interface Serial0/3/0
no ip address
shutdown
no fair-queue
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.55.100.1
ip http server
--More--                           no ip http secure-server
snmp-server community R1v3rH0rs3 RW
snmp-server community H1PP0$ RO
radius-server host 10.55.55.32 auth-port 1645 acct-port 1646 key 7 132D02061F5C45390F
radius-server host 10.55.55.10 auth-port 1645 acct-port 1646 key 7 032C4E1F125F605F6A
control-plane
voice-port 0/0/0:23
translation-profile incoming BLOCK
voice-port 0/1/0
trunk-group POTS 1
description POTS line
voice-port 0/1/1
trunk-group POTS 5
voice-port 0/2/0
voice-port 0/2/1
dial-peer voice 911 pots
trunkgroup POTS
description *** Outbound 911 ***
destination-pattern 911
forward-digits 3
dial-peer voice 9911 pots
trunkgroup POTS
destination-pattern 9911
forward-digits 3
dial-peer voice 50 voip
preference 10
destination-pattern 759....
modem passthrough nse codec g711ulaw
session target ipv4:10.55.100.5
incoming called-number .T
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
codec g711ulaw
dial-peer voice 51 voip
preference 1
session target ipv4:10.200.100.5
codec g711ulaw
dial-peer voice 11 pots
destination-pattern 1..........
fax rate voice
direct-inward-dial
port 0/0/0:23
forward-digits all
dial-peer voice 12 pots
preference 1
destination-pattern [2-9]......
fax rate voice
direct-inward-dial
port 0/0/0:23
forward-digits all
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
ip source-address 10.55.100.2 port 2000
max-ephones 50
max-dn 100
system message primary SRST - Fallback
line con 0
line aux 0
line vty 0 4
transport input telnet ssh
scheduler allocate 20000 1000
ntp clock-period 17180297
ntp update-calendar
ntp server 10.55.1.1
end
at step 13, can you try copy running-config startup-config
and not wr
http://www.cisco.com/en/US/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml
did not work using the copy running-config startup-config.   Sometimes it looks like it takes the username and password and I get a display that looks like this.
TECH.SRST con0 is now available
Press Ret to get Started
When I hit return it goes back to
User Access Verification
Username:
the username/password was saved correctly and if you can't contact radius server you should fall back to local user/password so that's strange.
Regards.
Alain
Since this is not working, is it possibe to save my Configuration on this router, by copying the running config to a notepad and resetting the router to factory default and pasting the config back?  If not what is the best option if I cannot login into it.
yes you can do that.Don't forget you'll have to no shut all the interfaces.
Regards.
Alain
According to step 9 you do the following.
When, Cadet had you paste the configuration, I noticed that besides the cisco username there was an admin account and
a calence account? Are you able to log in with any of those?
I tried all of these, the last time someone tried to login was couple of years ago, and that person is gone.  The router has been working with no problems and it was when i tried to login to check the configuration that I found no one knew the passwords.
Does the router still have communication with the Radius server?
I have found the problem.  It was the radius statements.  I deleted the radius statements and used the username and password command and it worked this time.  When I finish working on my T1 issue, I will work on the Radius.  Thanks for all your help
Yeah, that's why I was asking about the Radius communication. From looking at the configuration I noticed that
radius was listed before local and line, so if there was still communication between the router and the Radius server
it should still be using radius. Let us know if it worked.
that's why I found it strange because all the interfaces were in shutdown state so he shouldn't communicate with the radius server and fallback to local database.
Regards.
Alain
I have a question.  when I put my Radius statements back in should they follow the local username and password or does it matter.
