Unable to delelte file from rootfs
ys173p
I'm trying to delete file from rootfs: on NCS5500 but can't:
path outside filesystem disallowing access
any thought?
del rootfs:harddisk:6.3.3
Fri Jun 5 15:44:41.505 UTC
delete : /harddisk:6.3.3 : path outside filesystem disallowing access
pieterh
search docs on Unix/Linux mount command.
maybe it is a "mounted" filesystem and you need to dismount first before you can delete the  mount-point?
