Unable to enable Policy-Map on interface (QOS)
s.kanth
Hi ,
Class and Policy maps are defined properly but when I am going to apply the policy-map on interface ,throwing an error as "'set' command is not supported in a 2nd level policymap".
Class/Policy map configuration given below ....
class-map match-any cm_traffic_control
  match access-group name acl_traffic_control
class-map match-any BE
  match access-group name be
class-map match-any cm_af4x
  match ip precedence 6
  match ip precedence 7
  match ip precedence 4
  match ip dscp cs6
  match ip dscp cs7
  match access-group name acl_af4x
  match protocol telnet
  match protocol citrix
  match protocol tftp
class-map match-any cm_af2x
  match access-group name acl_af2x
class-map match-any cm_af3x
  match protocol sqlnet
  match protocol sqlserver
  match access-group name acl_af3x
class-map match-any cm_voice
  match  dscp ef
  match ip precedence 5
  match ip rtp 16384 16383
  match access-group name acl_voice
policy-map pmmpls5
  class cm_voice
   set dscp ef
   police cir 8000
     conform-action transmit
     exceed-action set-dscp-transmit af41
   priority 8
  class cm_traffic_control
   police cir percent 20
     conform-action set-dscp-transmit af41
     exceed-action set-dscp-transmit af31
  class cm_af4x
   set dscp af41
   bandwidth remaining percent 40
  class cm_af3x
   set dscp af31
  class cm_af2x
   set dscp af21
   bandwidth remaining percent 15
  class BE
   set dscp default
   bandwidth remaining percent 5
policy-map traffic_Shaper
  description includes Exchange Traffic
  class class-default
   shape average percent 95
   service-policy pmmpls5
Model of the router : cisco 1760 (Version 12.2(15)T1)
Thanks in advance
8 Replies 8
Jose Bogantes
This behavior is expected for 'set' command is not supported in a nested policy.
But same policy map is configured in multiple sites routers, no issues found (on 2800 routers ).
This could be related to the IOS for 12.2(15)T1 is a pretty old IOS release (deferred release). It is indeed a Pre-HQF image and it would be the root of the problem. I guess the working routers (2800) are using an HQF image and the policy works fine because of this fact. We have to remember that HQF was introduced with 12.4(20)T and it seems to be there are no HQF images available for 1760s (latest release is 12.4.15T1) probably because this router is already an end-of-life product:
http://www.cisco.com/en/US/prod/collateral/routers/ps221/prod_end-of-life_notice0900aecd8044473f.html
HQF:
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/qos_frhqf_support.html
However, I guess that you could directly apply the policy-map pmmpls5 under the interface and it will work for it will not be a CHILD policy-map. The only limitation is that the shaping mechanism of the traffic_Shaper policy-map will not be available for you (shape average percent 95).
Thanks Jose, I will upgrade the IOS on the router and try to implement the QOS.
New IOS loaded into flash of router (cisco 1760) and gave two IOS on boot system...
boot system flash c1700-k9o3sy7-mz.124-15.T14.bin   ---- ( New IOS )
boot system flash c1700-k9o3sy7-mz.122-15.T1.bin   ---- ( Old IOS )
But router is loading with the Old IOS. Any guess idea why the router is not loading with new IOS.
Sri
I think it should be like below.
boot system flash:c1700-k9o3sy7-mz.124-15.T14.bin
I suggest u remove the old boot statement and enter the new one.
we can not take the rest ,as we log into the device remotely.( Router is located in other region of the globe)
If the router is not loaded with the new IOS ,then it's gone :-(
Sri
Hello S.kanth,
My main concern is that there are no HQF images for this router so the best option will be directly applying the 2nd level policy-map. Remember that HQF was introduced with 12.4(20)T.
Regards.
