Unable to ping ipv6 address until router has initiated a ping itself
calluuml
We have a Cisco ISR 4321 with the Gigabitethernet0 (management) port in a seperate VRF (Mgmt-intf).
It has been assigned an IPv6 address which cannot be reached until the router itself initiates a ping.
The Mgmt-intf VRF has been setup with a default route.
When testing connectivity from a directly connected switch on the same subnet in the same VLAN the pings fail unless the ISR starts a ping itself from then the ping from the switch to the ISR begin working.
I thought it may have been a bug but after not using the device for a few days the connectivity is lost again and some entries must have timed out.
I may be overlooking in regards to how IPv6 NDP works compared with ARP but I assume the directly connected switch should be able to find the switchport of a device on its own subnet?
use the 'distributed' option...
6 Replies 6
post the full running configuration of your ISR 4321...
show run
Building configuration...
Current configuration : 2191 bytes
! Last configuration change at 11:12:44 UTC Fri Jul 10 2020 by admin
version 16.6
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname xxxxxxxx
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 xxxxxxxxxx
no aaa new-model
ip name-server x.x.x.x x.x.x.x
ip name-server vrf Mgmt-intf x.x.x.x x.x.x.x
ip domain name xxx.org.uk
subscriber templating
license udi pid ISR4321/K9 sn xxxxxxxxxxxxx
diagnostic bootup level minimal
username xxxxx secret 5 xxxxxxxxxxxxxxx
redundancy
mode none
interface GigabitEthernet0/0/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
ip address x.x.x.x 255.255.0.0
negotiation auto
ipv6 address xxxx:xxxx:xxxx:10::95:4/64
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route vrf Mgmt-intf 0.0.0.0 0.0.0.0 x.x.x.x
ipv6 route vrf Mgmt-intf xxxx:xxxx:xxxx::/56 GigabitEthernet0 xxxx:xxxx:xxxx:10::3
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
banner login ^C
xxxx
^C
banner motd ^C
xxxxxx
^C
line con 0
exec-timeout 5 0
logging synchronous
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
ntp server xxx.org.uk
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
not sure if that should be visible in the running config, but try and configure:
ipv6 cef
These are the options;
xxx(config)#ipv6 cef ?
accounting Enable CEF accounting
distributed Distributed Cisco Express Forwarding for IPv6
load-sharing Load sharing
optimize Optimizations
traffic-statistics Enable collection of traffic statistics
working now thank you
