DHCP Issue on VRF
Learnercisco
Hi Teck People
i am facing on strang issue in my Distribution 9600 if some body face this issue guide me please
IP phone is not getting IP Address from Cisco 96000 DHCP Server but Serve is showing the binding:
DHCP SERVER Binding:
Switch-1A#show ip dhcp binding
Bindings from all pools not associated with VRF:
IP address      Client-ID/              Lease expiration        Type       State      Interface
                Hardware address/
                User name
Bindings from VRF pool Telephone:
                Hardware address/
                User name
172.17.30.14    01a4.b239.4805.6f       Infinite                Automatic  Active     Vlan67
Switch-1A#
DHCP Server Confguration
ip dhcp use vrf connected
ip dhcp excluded-address vrf Telephone 172.17.30.1 172.17.30.2
ip dhcp pool TPH-67
vrf Telephone
network 172.17.30.0 255.255.255.0
default-router 172.17.30.1
option 150 instance 1 ip 172.17.50.5
option 150 instance 2 ip 172.17.50.6
lease infinite
ip dhcp snooping information option allow-untrusted
can somebody suggest
Hi George Thanks for your Support
we have two seprate cluster for Distribution.
Finally the issue solved by upgrading on the IOS of Distribution Swiitches
Platform C9606R
Presinstalled IOS version:16.12.02
Upgraded IOS version: 16.12.3a (This s a stable version )
Thanks for Support from Everyone.
32 Replies 32
Mark Elsen
 - Take a look at this  thread (not really the subject) , but how DHCP is setup with vrf interfaces :
            https://community.cisco.com/t5/switching/no-ip-dhcp-use-vrf-connected/td-p/1334822
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
hi marce,
I suppose my configuration is correct
Request is coming from the access Switch vlan via trunk port to distribution SVI under same VRF and DHCP Pool is under same VRF.
With the ip dhcp use vrf connected, the behavior becomes what you would normally expect - the requests from the Fa0/0.10 will be served from the DHCP pool Global, the requsts coming through the Fa0/0.20 in VRF MyVRF1 will be served from the DHCP pool ForMyVRF1 and finally the requests from Fa0/0.30 will be served from the DHCP pool ForMyVRF2 as the Fa0/0.30 is assigned to the MyVRF2.
balaji.bandi
Can you post below command :
show run interface vlan 67
show run interface te x/x ( te or tw) depends on environment. - where the Phone connected not getting IP address
you can also check IP arp / MAC table and see where this IP allocated to what port ?
make sure the port need to belong to same VRF to serve IP address.
BB
Thanks Balaji.
The phone is connected to access swith via layer 2 MEC to distribution swith and TPH vlan is trunk to the access swith.
i have no arp entry for Telephone VRF on distribution swith. This is strange for me e.g show ip arp Telephone
yes the port belongs to same vrf
Please provide all relavant configuration to review
BB
the configuration on  access
switch below
int g1/0/1
switchport mode access
switchport voice vlan 67
spanning-tree port fast
The vlan 67 is trunk to distribution through a L2 etherchannel. vtp mode transparent
access Switch configuration
interface TenGigabitEthernet1/1/1
description <<<< Conection to Distribution 1 >>>>
switchport mode trunk
switchport nonegotiate
channel-group 1 mode passive
interface TenGigabitEthernet1/1/2
description <<<< Conection to Distribution 2 >>>>
switchport nonegotiatechannel-group 1 mode passive
Distribution Switch Configuration:
interface TwentyFiveGigE1/1/0/2
description ### Conection to Access Switch-1 port 1 ###
switchport trunk allowed vlan 67,911
channel-group 21 mode active
interface TwentyFiveGigE2/1/0/2
description ### Conection to Access Switch- 1 port 2 ###
how about removing switchport trunk allowed vlan 67,911  config from Po21 and try ?
BB
Hi Balaji
as per my understandng,
Access and distribution are in transparent mode so i need to allow the specifice vlan  from Access to distribution as i did from Distribution to Access. for example below. because vlan 911 in Managemnt VRF and i can see arp entries under Management VRF. but i cant see the arp for Telephone VRF in distribution switch for vlan 67. in short i want to allow the same vlan from Access to distribution and distribution to accees. please correct me if i am wrong.
access to distribution
description <<<< Conection to Distribution 1A >>>>
switchport mode trunk allowed vlan 67,911
description <<<< Conection to Distribution 1B >>>>
switchport mode trunk vlan 67,911
interface Port-channel1
description <<<< Conection to Distribution 1A,1B >>>>
description ### Conection to Access Switch-1 ###
interface Port-channel21
description <<<< Conection to acces switc 01 >>>>
is this typo or configuration wrong here - different configuration in each interface: that is not causing the issue, just checking?
just to clarify, is this VRF in distribution switch?
what is the model of distribution/access switch what version of code running on both?
just to check what happens when you change the access VLAN from voice VLAN 67 to normal VLAN 67 ? do you get an IP address?
Also i see the port belong to switchport voice vlan 10, do you have VLAN 10, or change that to VLAN 67 and try ?
BB
switchport mode trunk vlan 67,911 type mistake
ust to clarify, is this VRF in distribution switch? >>>>>>> yes
16.12.2 9600/9300
just to check what happens when you change the access VLAN from voice VLAN 67 to normal VLAN 67 ? do you get an IP address? >>>>>>>>i will check it and update
sorry forget to add portchannel from distribution
description <<<< Conection to 570BG002TLSW-0001 >>>>
what is the port configuration of the connected device ?
switch below
int g1/0/1
The vlan 10 is trunk to distribution through a L2 etherchannel.
you need to allow Vlan 10 on the trunks. Remove the lines in bold (from the port channel as well):
--> no switchport trunk allowed vlan 67,911
