Unable to reach DNS server on Cisco 881 router
matjxa
I am trying to set up a DNS server on the router for my local network, these are my configs:
Current configuration : 1439 bytes
! Last configuration change at 00:14:16 UTC Tue Jan 9 1900
version 15.1
no service pad
hostname Labnet
boot-start-marker
boot-end-marker
enable secret 5 $1$Ui8u$eoLJUOpxlga4iYrqK6pvX/
enable password *******************
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 192.168.15.1 192.168.15.2
ip dhcp pool labnet
  network 192.168.15.0 255.255.255.0
  dns-server 192.168.15.1
  default-router 192.168.15.1
  domain-name example.local
ip dhcp pool MAINSERVER
  host 192.168.15.3 255.255.255.0
  client-identifier ****.****.****.**
ip dhcp update dns both override
ip cef
ip host gerrit.example.local 192.168.15.3
no ipv6 cef
license udi pid CISCO881-K9 sn FCZ1517C5M7
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
  shutdown
interface FastEthernet3
  shutdown
interface FastEthernet4
  no ip address
  shutdown
  duplex auto
  speed auto
interface Vlan1
  ip address 192.168.15.1 255.255.255.0
  ip nat inside
  ip virtual-reassembly in
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip dns spoofing
logging esm config
line con 0
  no modem enable
line aux 0
line vty 0 4
  login
  transport input all
end
I have a server that I want to give the domain name gerrit.example.local. Pinging gerrit.example.local from the router works fine, but when I try to access gerrit.example.local from another computer on the network it does not work:
$ nslookup gerrit.example.local
Server: 127.0.0.53
Address: 127.0.0.53#53
Non-authoritative answer:
Address: 192.168.15.1
;; connection timed out; no servers could be reached
$ nslookup gerrit.example.local 192.168.15.1
Server: 192.168.15.1
Address: 192.168.15.1#53
I can ping 192.168.15.3 so the server can be reached, but the DNS does not work.
The server is connected directly to the FastEthernet1 port and the other computer is connected to FastEthernet0 through an HP switch, if that is relevant. (Also I don't have internet access right now, that is why FastEthernet4 is not configured)
Best regards,
Mattias
M02@rt37
@matjxa,
Since you have DNS spoofing enabled on the router, consider temporarily disabling it to see if it affects the behavior. The
ip dns spoofing
command can sometimes cause unexpected issues.
Best regards
9 Replies 9
R1# configure terminal
R1(config)# ip dns server
R1(config)# ip domain-lookup
You need above to make router work as DNS
I open via PC is see command.
MHM
ip dns server is active, see the config in the first post.
M02@rt37
Helo @matjxa
ip domain-lookup is configured ?
Best regards
ip domain-lookup is configured (I guess it doesn't show up in running-config because it's on by default?), but it still doesn't work.
If I check systemd-resolve --status on the other computer it recognizes the router as a DNS server, so I don't understand why it doesn't work:
$ systemd-resolve --status
Link 2 (enp0s31f6)
Current Scopes: DNS
DefaultRoute setting: yes
LLMNR setting: yes
MulticastDNS setting: no
DNSOverTLS setting: no
DNSSEC setting: no
DNSSEC supported: no
Current DNS Server: 192.168.15.1
DNS Servers: 192.168.15.1
DNS Domain: ~.
example.local
M02@rt37
@matjxa,
ip dns spoofing
Best regards
I disabled DNS spoofing and now it works!
It seems to be very slow though. When I ping gerrit.example.local it takes around 15 seconds before anything happens. What could be the cause of this?
Great @matjxa
Clear the DNS cache on both the router and the client to ensure that you are not dealing with outdated or incorrect DNS entries.
Best regards
Ip dns spoofing
Can slow but not stop dns'
For slow after remove spoofing
Add
Domain name example.local
Check this.
