Why it's not working?
shafayathridoy
I'm begainer. I am trying to reset my Cisco Catalyst 2960 switch. I follow the steps, and this interface is showing. What do you think I should do??
balaji.bandi
I followed below steps that should worked all the time :
1. Connect the console cable to switch and Turn off the switch.
2. Press Mode button
3. On the prompt, enter the following command: flash_init
4. delete config.text and vlan.dat from flash
5. boot
after boot you should see :
Would you like to enter the initial configuration dialog? [yes/no]:
BB
