Unable to Reverse Telnet from Router with V15.1 code
Zubair.Sayed_2
Hi All.
We have a router that was installed a few months ago which has the following version: 15.1(3)T
I am unable to reverse telnet to a new ASA firewall, however when I move the console to a second older router with an older version of code I am able to reverse telnet
Are there any known bugs, issues with version 15.1 or am I missing something?
I use the following command as normal: telnet x.x.x.x 2001
Zubair
5 Replies 5
Peter Paluch
Zubair,
Please attach your current running configuration if possible (please remove the sensitive information, though). To which port is the ASA connected?
Best regards,
Peter
Peter,
Do you require the config for the Router or the ASA, the ASA is a new device and hence has no config.
Connecting the console from the router AUX port to the ASA Console port.
Does ver 15.x perhaps only support SSH using reverse telnet?
Zubair
Hello Zubair,
I am interested in seing the router's configuration. The SSH Reverse Access should be supported on the 15.1 but I do not believe that the option of the plain old reverse telnet was removed.
Thank you!
Best regards,
Peter
Peter,
Please see below:
MyRouter#sh run
Building configuration...
Current configuration : 19423 bytes
version 15.1
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service compress-config
service sequence-numbers
hostname MyRouter
boot-start-marker
boot system flash0:
boot system flash0
boot system flash0:/c2900-universalk9-mz.SPA.151-3.T.bin
boot system flash:c2900-universalk9-mz.SPA.151-3.T.bin
boot system flash0:c2900-universalk9-mz.SPA.151-3.T.bin
boot-end-marker
enable secret xxxxxxxxxxxxxxxxxxxxxxxxxxx
aaa new-model
aaa session-id common
no ipv6 cef
no ip source-route
no ip gratuitous-arps
ip cef
no ip mfib
no ip bootp server
no ip domain lookup
ip domain name
ip wccp 61 redirect-list xxx
ip wccp 62 redirect-list xxx
crypto pki trustpoint TP-self-signed-3443541981
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3443541981
revocation-check none
crypto pki certificate chain TP-self-signed-3443541981
license udi pid CISCO2921/K9
archive
log config
  hidekeys
ip tcp synwait-time 10
ip tftp source-interface GigabitEthernet0/0
ip ssh time-out 60
ip ssh version 2
interface Loopbackxxx
ip address
interface GigabitEthernet0/1
interface GigabitEthernet0/2
ip forward-protocol nd
control-plane host
control-plane
line con 0
exec-timeout 15 0
login authentication admin_only
transport output all
stopbits 1
line aux 0
authorization commands 1 no_acs
authorization exec no_acs
login authentication no_acs
modem InOut
no exec
transport preferred telnet
transport input all
transport output telnet
stopbits 1
flowcontrol hardware
line vty 0 4
access-class 99 in vrf-also
exec-timeout 15 0
privilege level 15
transport input ssh
line vty 5 15
privilege level 15
transport input ssh
scheduler allocate 20000 1000
end
Zubair,
I see no obvious problem with your configuration. I suggest first removing the superfluous commands from your AUX, i.e. making it only:
line aux 0
no exec
transport input all
stopbits 1
flowcontrol NONE
In addition, I assume you are reverse-telnetting into the TCP port 2001. Is the port enabled in all ACLs and other firewalls you may have configured on your router? Can you telnet directly from the router itself to any of its IP address, port 2001? How does the failure exactly look like - frozen command line, some error message, connection refused etc...?
Best regards,
Peter
