Unable to Telent(Destination unreachable; gateway or host down )
adhityakarthik
hi all
I need to restict telnet access to switches, mean i should able to telnet LAN Switches from core switch mangement vlan.
I have apllied ACL, but after applying ACL, i am able to ping access switch but i am unable to telnet, config is pasted below can some one help plz
On Core switch
int vlan 171
description Mgmt vlan
ip address 172.17.1.2 255.255.255.0
On access siwth i have apllied this config
access-list 110 permit ip 172.17.1.0 0.0.0.255 any
access-list 110 deny ip any any log
And on vlan interface i have apllied this
int vla171
ip aceess group 110 in
after this iam able to pin access switch from the core but uanble to telnet
erros pasted below
Core1ping 172.17.1.10
Sending 5, 100-byte ICMP Echos to 172.17.1.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Core-DC-1#tel
Core-DC-1#telnet 172.17.1.10
Trying 172.17.1.10 ...
% Destination unreachable; gateway or host down
Please help me on the same
srinivas sagar
14 Replies 14
cisco_lad2004
Level 5
Level 5
apply ACL under instead line VTY 0 4 and later 5 15.
conf t
line vty 0 4
access-class 110 in
end
Sam
Thanks very much for the update.
My erequirement is not only telnet but to allowSNMP servers and other montiroing tools to pool, i got requirement to apply on mangement vlan could you please gucid eme
Srinivas
please re test with telnet /source-interface vlan 171
this will confirm if u have any routing issues. if u can PING, u should be able to telnet unless going thru FW or further ACLs that re misleading u.
please inc show ip route from core for SWITCH management VLAN.
Sam
HI
i am able to ping and do the tracert
Core-DC-1#p 172.17.1.10
Core-DC-1#tel
Core-DC-1#traceroute 172.17.1.10
Tracing the route to 172.17.1.10
1 172.17.1.10 0 msec * 0 msec
Core-DC-1#q
Io route
Core-DC-1#sh ip route | in 172.17.1.0
C 172.17.1.0/24 is directly connected, Vlan171
Core-DC-1#
Rinivasa
HI
Core-DC-1#tel
Core-DC-1#q
Io route
Core-DC-1#
Rinivasa
Rinivasa,
Ur config should work.
veriffy that there are no other ACLs on physical ports / trunks that may cause this.
Its a straight forward setup and should work.
Sam
there are no ACSL in the access siwth it has not worked
do u want to me to check any thing on core
srinivasa
what do u get when u telnet this way ?
telnet 172.17.1.10 /source-interface vlan 171
If u get through, then check that you have this line configured.
"ip telnet source-interface" which is corrupting your telnet source.
i will check this
have not configured ip telnet source itnerface vlan
find my config below
ip tacacs source-interface Vlan171
logging source-interface Vlan171
snmp-server trap-source Vlan171
Srinivasa
i will check this
Srinivasa
Thanks for the update.
I havnet tried, will try later in the evening
Please note that its a stack Switch(5 Switches connected in sack) and i am doing it remotely
srinivasa
amitmarathe
Just check the source interface when you telnet to the switch.
i didnt get you
srinivasa
