Understanding OSPF Metric with BGP redistribution + route-map
roger perkin
Level 2
Level 2
I need to understand the OSPF metric and have a level of confusion which I am hoping someone can clarify for me?
We have our MPLS WAN redistributing all the routes from BGP into OSPF
CE Router:
router ospf 1
log-adjacency-changes
redistribute bgp 64993 subnets
On my WAN switch (connected to CE router) I have a network 10.188.3.0 which shows as below.
O E2    10.188.3.0/24 [110/1] via 10.251.251.98, 00:00:54, FastEthernet1/0
According to my knowledge this has a Distance of 110 (OSPF) and a metric of 1 (Not exactly sure what this means?)
We also have a bakckup link which I want to affect traffic to go over.
So I make this change
CE Router:
router ospf 1
redistribute bgp 64993 subnets route-map BGP_to_OSPF
Currently the route-map does not exist??
But his happens on WAN switch
*Mar  1 18:18:47.235: RT: del 10.188.3.0/24 via 10.251.251.98, ospf metric [110/1]
*Mar  1 18:18:47.235: RT: delete subnet route to 10.188.3.0/24
*Mar  1 18:18:47.235: RT: NET-RED 10.188.3.0/24
*Mar  1 18:18:47.235: RT: NET-RED queued, Queue size 1
*Mar  1 18:18:47.235: RT: add 10.188.3.0/24 via 10.251.251.209, ospf metric [110/20]
Now sh ip route on WAN Switch shows this
O E2    10.188.3.0/24 [110/20] via 10.251.251.209, 00:01:45, FastEthernet0/0
It is now taking a different path because metric is now 20?
Why does redistributing with a route-map statement that does not exist cause this behaviour?
Many Thanks
Roger
milan.kulik
Level 10
Level 10
IMHO, it should make no difference.
" If no metric is specified, OSPF puts a default value of 20 when redistributing routes from all protocols except BGP routes, which get a metric of 1. The metric-type is discussed in the next paragraph."
See
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080094e9e.shtml#t32 for details.
As the next-hop is also different, are you sure the new route is still redistributed from your BGP router?
Isn't it received from other device?
HTH,
Milan
