Unexpected Frame-Relay results
Markfrancis910
Hello all,
I have a simple home lab with a simple WAN connection going through a 2522 acting as a Frame Relay switch. I have managed in the past to get full connectivity but am unable to recreate it now. Please can you show me where I might be going wrong.
R1
interface Serial0/0
ip address 200.0.0.1 255.255.255.0
encapsulation frame-relay
frame-relay map ip 200.0.0.2 101 broadcast
no frame-relay inverse-arp
R1#show interface serial 0/0
Serial0/0 is down, line protocol is down
  Hardware is PowerQUICC Serial
  Internet address is 200.0.0.1/24
  MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
  Encapsulation FRAME-RELAY, loopback not set
  Keepalive set (10 sec)
  LMI enq sent  114, LMI stat recvd 114, LMI upd recvd 0, DTE LMI down
  LMI enq recvd 0, LMI stat sent  0, LMI upd sent  0
  LMI DLCI 1023  LMI type is CISCO  frame relay DTE
  Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0
  Last input 00:25:25, output 00:25:25, output hang never
  Last clearing of "show interface" counters 00:44:41
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
     114 packets input, 1642 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     118 packets output, 1536 bytes, 0 underruns
     0 output errors, 0 collisions, 53 interface resets
     5 carrier transitions
     DCD=down  DSR=down  DTR=up  RTS=up  CTS=down
R1#show frame-relay map
Serial0/0 (down): ip 200.0.0.2 dlci 101(0x65,0x1850), static,
              broadcast,
              CISCO, status deleted
Frame Relay switch
hostname FR1
frame-relay switching
interface Serial0
no ip address
clockrate 56000
frame-relay intf-type dce
frame-relay route 101 interface Serial1 202
interface Serial1
no ip address
no keepalive
clockrate 56000
frame-relay route 202 interface Serial0 101
Show Frame-Relay map
Input Intf      Input Dlci      Output Intf     Output Dlci     Status
Serial0         101             Serial1         202            inactive
Serial1         202             Serial0         101             static
R2
interface Serial0/0
ip address 200.0.0.2 255.255.255.0
shutdown
no keepalive
frame-relay map ip 200.0.0.1 202 broadcast
R2#show interface serial 0/0
  Internet address is 200.0.0.2/24
  MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec,
  Keepalive not set
  CRC checking enabled
  FR SVC disabled, LAPF state down
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:35:02
     Conversations  0/0/256 (active/max active/max total)
     0 packets input, 0 bytes, 0 no buffer
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
     3 unknown protocol drops
     0 carrier transitions
R2#show frame-relay map
Serial0/0 (down): ip 200.0.0.1 dlci 202(0xCA,0x30A0), static,
              broadcast,
              CISCO
John Blakley
Mark,
It looks like s0/0 is shut on R2...
HTH,
John
HTH, John *** Please rate all useful posts ***
Mark
I believe that John has correctly identified the most serious problem as being that R2 has shutdown on the interface. I also notice that R1 the interface shows as line is down and line protocol is down. Usually that indicates a basic lack of connectivity on the interface and would reflect the connection from R1 to the frame relay switch. I am not sure that it would be caused by the problem on R2. After you fix the problem with shutdown on R2 I suggest that you check the interface on R1 again and if it is still down/down then you have additional troubleshooting to do.
Rick
Rick
