Unexpected reboot 4948E
valintinr
We have before Cisco 65 with 720 Sup but we have to replace it with 4948E. Configured (copied from prewious one) BGP with multiple peers and traffic shaping (copied too) per ip via policy-map.
Now when I try to change shape shaper 4948E suddenly rebooted. I've tried this few time and rebboted every time.
Some tech info.
Log Buffer (4096 bytes):
*Jul 26 10:29:22.199: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jul 26 10:29:24.139: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-C4948E S/N: CAT1601S3YS Hw: 2.0) is online
*Jul 26 13:29:24: %SYS-6-CLOCKUPDATE: System clock has been updated from 10:29:24 UTC Tue Jul 26 2016 to 13:29:24 EET Tue Jul 26 2016, configured from console by console.
*Jul 26 13:29:26: %SYS-5-CONFIG_I: Configured from memory by console
*Jul 26 13:29:26: %SYS-5-RESTART: System restarted --
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 15.2(1)E, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 27-Aug-13 12:44 by prod_rel_team
*Jul 26 13:29:26: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jul 26 13:29:26: %SNMP-5-COLDSTART: SNMP agent on host SW35-UA is undergoing a cold start
*Jul 26 13:29:31: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=49: Transceiver has been inserted
*Jul 26 13:29:34: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=50: Transceiver has been inserted
*Jul 26 13:29:37: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=51: Transceiver has been inserted
*Jul 26 13:29:38: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=52: Transceiver has been inserted
*Jul 26 13:30:06: %BGP-5-ADJCHANGE: neighbor 31.28.16.1 Up
*Jul 26 13:30:13: %BGP-5-NBR_RESET: Neighbor 194.44.6.233 active reset (BGP Notification sent)
*Jul 26 13:30:13: %BGP-5-ADJCHANGE: neighbor 194.44.6.233 Up
*Jul 26 13:30:16: %BGP-5-ADJCHANGE: neighbor 195.211.108.126 Up
*Jul 26 13:30:18: %BGP-5-ADJCHANGE: neighbor 195.35.65.11 Up
*Jul 26 13:30:22: %BGP-5-ADJCHANGE: neighbor 195.211.108.122 Up
SW35-UA#show version
ROM: 12.2(44r)SG11
SW35-UA uptime is 4 minutes
System returned to ROM by abort at PC 0x0
System restarted at 13:28:47 EET Tue Jul 26 2016
System image file is "bootflash:cat4500e-entservicesk9-mz.152-1.E.bin"
Hobgoblin Revision 21, Fortooine Revision 1.40
Last reload reason: abort at PC 0x0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4948E (MPC8548) processor (revision 5) with 1048576K bytes of memory.
Processor board ID CAT1601S3YS
MPC8548 CPU at 1GHz, Cisco Catalyst 4948E
Last reset from System Crash
10 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
vlan configuration 233,237
service-policy output World-out-pmap
interface TenGigabitEthernet1/51
switchport access vlan 233
switchport mode access
no cdp enable
spanning-tree bpdufilter enable
spanning-tree bpduguard disable
spanning-tree guard none
service-policy input World-in-pmap
ip access-list standard Positive-Plus-out-acl
permit 195.xxx
ip access-list extended Positive-Plus-in-acl
permit ip any host 195.xxx
class-map match-all Positive-Plus-in-cmap
match access-group name Positive-Plus-in-acl
class-map match-all Positive-Plus-out-cmap
match access-group name Positive-Plus-out-acl
policy-map World-out-pmap
class Positive-Plus-out-cmap
police cir 20000000 bc 75000 be 75000 conform-action transmit exceed-action drop violate-action drop
policy-map World-in-pmap
class Positive-Plus-in-cmap
So I've typed next command
SW35-UA(config)#policy-map World-out-pmap
SW35-UA(config-pmap)# class Positive-Plus-out-cmap
SW35-UA(config-pmap-c)#no police cir 20000000 bc 75000 be 75000 conform-action transmit exceed-action drop violate-action drop
SW35-UA(config-pmap-c)#police cir 20000000 bc 75000 be 75000 conform-action transmit exceed-action drop violate-actissh: Write failed: Broken pipe
As you see after no police I have few second before reboot (I've used UP arrow to replace 20M within 50M). That's all
valintinr
Fixed after upgrading to   Version 15.1(2)SG7
