Unsupported L4 protocol type match
I am implementing QOS on cisco ME-3600X-24FS-M and i have problems when i want to attach the service policy on a physical interface
To simplify i have juste 1 class-map in 1 policy-map.. "Access-group"does not work.. :
mpe1#sh class-map
 Class Map match-any class-default (id 0)
   Match any
 Class Map match-all Network-Routing (id 1)
   Match access-group name Network-Routing
mpe1#sh policy-map
  Policy Map test
    Class Network-Routing
      set dscp cs7
mpe1#sh access-lists
Extended IP access list Network-Routing
    10 permit ospf any any
mpe1(config-if)#service-policy input test
QoS: Unsupported L4 protocol type match
QoS: Policy attachment failed for policymap test
Thank you for your help,
Maxime Jego
Richard Burts
Maxime
Would you post the configuration of the interface to which you attempt to apply this? My guess is that it is a layer 2 interface and the service-policy would be applied on a layer 3 interface but it might be some other factor.
Rick
Rick
Richard,
First, thank you for reply.
It is really a L3 interface. Look :
interface GigabitEthernet0/24
 description ***: ***-mpe-1 / ***-mpc-1 (gi0/5/0) - 1G
 no switchport
 mtu 1550
 ip address 10.128.0.70 255.255.255.252
 ip ospf authentication message-digest
 ip ospf message-digest-key 1 md5 7 0455180F2F0E7F7E2F
 ip ospf cost 10
 mpls ip
 mpls mtu 1540
end
I have opened a case on cisco support and they says me that :
"I have found an internal bug state the following protocols ONLY types can be classified :
L4 - IGMP, TCP, UDP, ICMP, IPINIP, GRE.
Also am trying to reach the developer engineer to confirm that"
So I wait the confirmation but if i can't classify OSPF traffic, it will be very problematic.
Maxime
Thank you for the additional information. It certainly is a layer 3 interface and so my guess was off the mark. It is an interesting (and disappointing) possibility that they layer 4 protocols that can be matched are so limited. Please let us know if you find out more about this.
Rick
Rick
