UP/DOWN SITUATION. PLS HELP
cisco steps
I have up / down situation, after verifying all the config , we decided that this may be wic card issue , now I got a wic installed , still up/down. I created a harloop cable and put on the t1 port , I do not see the loop, there is a LP, AL, DC Led . Only the DC is green, I should see the LP when the loop is present. Since there is no loop when I put the hard loop is that mean bad card, this is the second card that I received and it shows up/down
#sho int s1/1:0
Serial1/1:0 is up, line protocol is down
Hardware is DSCC4 Serial
Internet address is x.x.x.x/30
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
reliability 216/255, txload 1/255, rxload 1/255
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters 13:14:10
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/2/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
5730 input errors, 8 CRC, 5722 frame, 0 overrun, 0 ignored, 0 abort
4765 packets output, 114360 bytes, 0 underruns
0 output errors, 0 collisions, 1588 interface resets
0 carrier transitions
Timeslot(s) Used:1-24, SCC: 1, Transmitter delay is 0 flags
21 Replies 21
loop plug is good I tested on the NIU to provide loop facing the other direction ..
Now I was going to change the slot from 1 to 4 I could not configure slot 4, when I do :
(config)#controller t1 4/1
% Invalid input detected at '^' marker.
When using loop plug, set clock internal and check show controller again.
Reseat modulse and check "show diag" when HW is not recognized.
Note on ISR routers, need to turn off router when swapping modules.
you mean like this
config t #
controller T1 1/0
framing esf
linecode b8zs
cablelength short 133
channel-group 0 timeslots 1-24 speed 64
clock internal
can you pls show me the steps
I did set the clock to internal . now it shows in sho controllers
#sho controllers t1
T1 1/0 is up.
Applique type is Channelized T1
Cablelength is short 133
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20031216, FPGA: 11
Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
====I did reseat the controller 1/0
====I do have loop plug on 1/0
still no loop
encap is hdlc
still no loop
Update IOS, I see from "firmware version" that what you're using is quite old.
pompeychimes
Level 4
Level 4
Any extended wiring involved. If so are you pinned out correctly for a T1 (1,2,4,5)
good news...
since there was no hard loop in the wic. I changed the slot from 1/1 and 1/0 to 4/0 and 4/1 now I have up/up .. Thanks all for your support and feed back, I will go back and rate every one that contributed there time,
Thanks all
