update my router Cisco ISR4431/K9
chaterayoub1
Hello
I'm using cisco ISR4431/K9 (1RU) processor with the IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
System image file is "bootflash:isr4400-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
 My problem :
Is this version of software indicated for the realization of an interface Bridge domain or it is necessary to make an update? If yes can u tell what version should I download?
I hope you can help me.
Thanks for your time.
eric.ahernandez
As far as I know there shouldn't be a problem in configuring bridge-domains with that IOS version, it does not limit that capability, have you tried configuring and ran into a problem?
Another thing, that version you have seems to be a deferred release and is from like 2016, so I would recommend upgrading to one of the more recent Cisco recommended versions for more stability.
