Updating bandwidth to a network
Hargert42
I am looking to add a new connection between a Cisco 2851 and a Cisco 3745.  Currently there are two T1 connections between them for a internal 192.168.5.0 network but I would like to add a ethernet connection to give a larger pipe for when transfering large files via that network.  Can I just add the ethernet to the multigroup and shut the ethernet connection down when not needed(to limit it to t1 speeds) or is there some other way of doing this?
I have added the configs and a rough diagram below.  Currently the shutdown ethernet connections are unused and would be reconfigured.
Thank You.
First device 2851
Current configuration : 6157 bytes
version 12.4
service password-encryption
hostname 2851
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.124-11.XW6.bin
boot system flash:c2800nm-adventerprisek9-mz.123-11.T7.bin
boot-end-marker
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default local group tacacs+
aaa authorization network default group tacacs+ local
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 7 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
clock timezone mst -7
clock summer-time mdt recurring
no network-clock-participate wic 0
no network-clock-participate wic 1
ip cef
ip domain name blmntl.gov
voice-card 0
no dspfarm
controller T1 0/0/0
framing esf
linecode b8zs
cablelength short 133
channel-group 0 timeslots 1-24
controller T1 0/0/1
framing esf
linecode b8zs
controller T1 0/1/0
framing esf
linecode b8zs
controller T1 0/1/1
framing esf
linecode b8zs
ip ssh time-out 60
ip ssh authentication-retries 4
interface Loopback0
ip address 192.168.63.3 255.255.255.255
interface Multilink1
description To State
ip address 192.168.0.6 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ppp multilink
ppp multilink group 1
interface GigabitEthernet0/0
description To Infra-6506 G2/3
no ip address
ip route-cache flow
duplex auto
speed auto
interface GigabitEthernet0/0.801
encapsulation dot1Q 801
ip address 192.168.5.1 255.255.255.0
ip helper-address 192.168.5.27
ip helper-address 192.168.5.55
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:0
description To 3745-Edge S0/0:0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial0/1/0:0
description To 3745-Edge S0/2
no ip address
encapsulation ppp
ppp multilink
ip route 0.0.0.0 0.0.0.0 192.168.0.5
ip route 192.168.5.0 255.255.255.0 192.168.62.5
ip route 192.168.63.4 255.255.255.255 192.168.62.5
ip flow-export version 5
ip flow-export destination 192.168.128.202 3000
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip tacacs source-interface GigabitEthernet0/0
logging 192.168.128.20
access-list 23 permit 10.10.10.0 0.0.0.7
tacacs-server host 10.121.33.55
tacacs-server host 10.121.49.55
tacacs-server directed-request
tacacs-server key 7 0010161510570A04
control-plane
alias exec c config t
line con 0
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
password 7
transport input ssh
line vty 5 15
privilege level 15
password 7
transport input ssh
scheduler allocate 20000 1000
ntp clock-period 17180356
ntp server 10.121.1.1 prefer
ntp server 10.121.81.1
end
Second device 3745
sh run
Building configuration...
Current configuration : 6043 bytes
version 12.3
hostname 3745-EDGE
boot-start-marker
boot system flash flash:c3745-adventerprisek9-mz.123-11.T10.bin
boot-end-marker
card type t3 1
card type t3 2
no logging console
aaa new-model
aaa group server tacacs+ tacacs1
server-private 10.121.33.55 key 7 071B245F5A051807
ip tacacs source-interface Serial1/0
aaa authentication ppp default group tacacs+ local
aaa authorization exec default group tacacs+ local
aaa authorization network default none
aaa accounting send stop-record authentication failure
aaa accounting update periodic 5
aaa accounting connection default start-stop group tacacs+
ip subnet-zero
ip cef
ip vrf ntl
rd 1:10
route-target export 1:10
route-target import 1:10
no ip bootp server
no ip domain lookup
ip ssh time-out 60
ip ips po max-events 100
no ftp-server write-enable
controller T1 0/0
framing esf
fdl both
clock source internal
linecode b8zs
channel-group 0 timeslots 1-24 speed 64
controller T1 0/1
framing esf
fdl both
linecode b8zs
channel-group 1 timeslots 1-24 speed 64
controller T3 1/0
controller T3 2/0
no crypto isakmp ccm
interface Loopback0
ip address 172.31.31.252 255.255.255.255
ip vrf forwarding ntl
ip address 192.168.0.5 255.255.255.252
ppp multilink
interface FastEthernet0/0
description To MPLS Core1
ip address 172.31.31.18 255.255.255.248
ip ospf network point-to-point
shutdown
speed 100
full-duplex
tag-switching ip
interface Serial0/0:0
description To 2851 S0/0/0:0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface FastEthernet0/1
description To ASR 1004
ip address 10.121.210.2 255.255.255.252
shutdown
speed 100
full-duplex
interface Serial0/1:1
description To 2851 S0/0/1:0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial0/2
description To NCFO-2821
ip address 192.168.0.9 255.255.255.252
encapsulation ppp
no fair-queue
interface Serial0/3
no ip address
shutdown
interface Serial1/0
description To NCR-Alpha S3/0
ip address 10.121.208.2 255.255.255.252
encapsulation ppp
dsu bandwidth 44210
interface Serial2/0
description To NCR-Beta S3/0
ip address 10.121.209.142 255.255.255.252
encapsulation ppp
dsu bandwidth 44210
router ospf 3745
router-id 172.31.31.252
log-adjacency-changes
passive-interface default
no passive-interface FastEthernet0/0
network 172.31.31.0 0.0.0.255 area 0
router bgp 64610
no synchronization
bgp log-neighbor-changes
redistribute connected
redistribute static
neighbor 10.121.208.1 remote-as 64700
neighbor 10.121.208.1 description To 3845-Alpha S3/0
neighbor 10.121.208.1 soft-reconfiguration inbound
neighbor 10.121.209.141 remote-as 64700
neighbor 10.121.209.141 description 3845-Beta S3/0
neighbor 10.121.209.141 soft-reconfiguration inbound
neighbor 172.31.31.251 remote-as 64610
neighbor 172.31.31.251 update-source Loopback0
no auto-summary
address-family vpnv4
neighbor 172.31.31.251 activate
neighbor 172.31.31.251 next-hop-self
neighbor 172.31.31.251 send-community extended
exit-address-family
address-family ipv4 vrf ntl
redistribute static
neighbor 10.121.208.1 activate
neighbor 10.121.209.141 activate
no auto-summary
no synchronization
exit-address-family
ip classless
ip route 0.0.0.0 0.0.0.0 172.31.31.251
ip route 192.168.128.0 255.255.255.0 10.121.208.1
ip route vrf abc 192.168.5.0 255.255.255.0 192.168.0.6
ip route vrf abc 192.168.6.0 255.255.255.0 192.168.0.10
ip route vrf abc 192.168.62.4 255.255.255.252 192.168.0.6
ip route vrf abc 192.168.63.3 255.255.255.255 192.168.0.6
ip route vrf abc 192.168.63.4 255.255.255.255 192.168.0.6
ip route vrf abc 192.168.63.5 255.255.255.255 192.168.0.10
no ip http server
no ip http secure-server
control-plane
dial-peer cor custom
alias exec c conf t
line con 0
exec-timeout 0 0
password 7
logging synchronous
escape-character 61
line aux 0
line vty 0 4
exec-timeout 0 0
password 7
logging synchronous
escape-character 61
end
3745-EDGE#
vmiller
Level 7
Level 7
Multilink is a serial interface feature, so no that won't work.
Why keep the T-1's if you have ethernet ?
you could consider some traffic shaping to manage who gets what.
It is for testing field connections that have limited bandwidth so I have to keep them due to management inisisting on it. My other thought was could I put them both in the same channel-group and do it that way.  Most of the time I would just have the ethernet in shutdown and just turn it on when I need to build a machine quickly so it wont take 4 hours to upload to it.
given your configs, I would suggest just manipulating static routes to whatever IP address block you use for building your devices. Don't mess with the T-1s.
