updating IOS, Reset Cisco 3750, no connection on serial poort?
Im a dummy and i'm recently started working with Cisco devices.
I want to make a test network where I want to accomplish vMotion.
I first want to configure the switch so that i can reach the IBM storage by IP.
the problem:
So im trying to configure the switch (Cisco 3750).
As i created a vlan etc. i tried connecting to the web interface. So i connect to the ip 192.168.1.22 and it worked.
I tried to acces the web console so i have a better view (because i am a dummy) about what's going on. This failed and it displayed a 404. I googled about this and i had to update the IOS image to c3750-ipbaselmk9-tar.122-55.SE9.tar and than i could access the web console. So i tried to update and followed the guide from a Cisco page. The image was on it but i could't get it proper to work but I tought it did so i rebooted the switch. I got an Error:
Loading "flash:c3750-ipbaselmk9-tar.122-55.SE9.tar"...flash:c3750-ipbaselmk9-tar.122-55.SE9.tar: no such file or directory
Error loading "flash:/c3560-ipservicesk9-mz.122-50.SE3.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically.  The BOOT
environment variable needs to be set to a bootable
image.
After that i came in Switch: mode. Not in Switch> or Switch# or whatsoever.
I gave an ? to see the commands and i saw a list with about 10? commands.
I also saw a Reset command and i tought this was a command to reset the switch to factory defaults. I gave the command and confirmed. After that i was'nt able to connect to the switch by console cable? I just can't reach my switch on IP nor Serial.
I have tried to Push the mode button and power off and power on the switch and holding the mode button for about 10 seconds but I still can't reach it..
Please help.
Me And You
A switch starts from a .bin file. Not .tar file.
You probably copied the .tar file but didn't do an extract on your switch.
