05-02-2016 10:02 AM - edited 03-05-2019 03:55 AM
How can I upgrade a WS-C3650-48PD-S from IP Base to ipservices license.
I guess there are some licenses but I don't seam to be able to find the P/N
Olivia
05-03-2016 10:41 PM
Hi Olivia,
You can use the option L-C3650-48-S-E under the top level SKU L-C3650-RTU=.
Refer the data sheet for licencing options.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3650-series-switches/datasheet-c78-729449.html
Hope this helps.
Dhammike.
Log in to Community
