Upgrade ASR 1004 not function
Dear Mister
I did a software upgrade in ASR 1004.
Before, i validate the butes quenatity, and verify the /md5 and SHA1 checksum, and both appear ok.
Weel, I did the reload and ... the nex message is showed:
Boot image size = 575615164 (0x224f30bc) bytes
Missing or illegal ip address for variable DEFAULT_GATEWAY
Using midplane macaddr
Missing or illegal ip address for variable IP_ADDRESS
Missing or illegal ip address for variable IP_SUBNET_MASK
Package header rev 0 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
    calculated 7b52fe47:34be7b71:c7f940d0:aec0555f:07422c42
    expected   6b6183f0:0cf0844e:501c4601:28b70000:b1d8c970
SHA-1 hash doesn't match
boot: error executing "boot bootflash:/asr1000rp2-advipservicesk9.03.08.02.S.153-1.S2.bin"
autoboot: boot failed, restarting...
Initializing Hardware ...
And the equipment started, with the before version:
asr1000rp2-advipservicesk9.03.05.01.S.152-1.S1.bin.
But, I validated before the CRC, and it was OK.
RETE1#verify bootflash:asr1000rp2-advipservicesk9.03.08.02.S.153-1.S2.bin
Verifying file integrity of bootflash:asr1000rp2-advipservicesk9.03.08.02.S.153-1.S2.bin...................
Embedded Hash   SHA1 : 6B6183F00CF0844E501C460128B70000B1D8C970
Computed Hash   SHA1 : 6B6183F00CF0844E501C460128B70000B1D8C970
Embedded hash verification successful.
RETE1#
RETE1#verify /md5 bootflash:asr1000rp2-advipservicesk9.03.08.02.S.153-1.S2.bin
verify /md5 (bootflash:asr1000rp2-advipservicesk9.03.08.02.S.153-1.S2.bin) = 436e340301ef258e394108a5578a7218
What could be the problem?????
Best Regards
JohnTylerPearce
Level 7
Level 7
Rodrigo,
When you upgrades the IOS, did you verify with 'show boot', that the parameters to inform the router, about which IOS to use when startup was configured correctly?
You may have to go to ROMMON Mode and try again. But it is strange, that when did 'verify /md5 path' that everything came out ok, and now, doesn't look like that's the case.
peteroseneff
To get rid of the error above you have to upgrade ROMMON to the latest verstion.
That worked for my ASR1006PR2 going to 15.3.  Thanks.
