upgrade CISCO 1841
kloyatweb
i'm pretty new on cisco products, but i've a big experience in routing and firewailling, using linux (debian)..
One of my customur ask me to replace a linux firewall by a cisco 1841, and he gaves me 2 cisco 1841 with HWIC-4ESW extention, with this ios version :
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(15)T10, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 14-Sep-09 12:41 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
fw uptime is 17 hours, 30 minutes
System returned to ROM by reload at 15:26:31 UTC Thu Mar 3 2011
System image file is "flash:c1841-ipbase-mz.124-15.T10.bin"
Cisco 1841 (revision 7.0) with 115712K/15360K bytes of memory.
Processor board ID FCZ134591GX
6 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31488K bytes of ATA CompactFlash (Read/Write)
When i'm trying to configure the firewall using SDM, it tells me that "the firewall feature is not available", can anyone tells me :
witch IOS to install ?
Is there a licence to pay? if so, any idear of the price ?
Do you have a document expaining the upgrade (Tftp ? X-modem tranfert ? upgrade via a web interface ?)
Thank's in advance.
Nico
2 Accepted Solutions
Leo Laohoo
can anyone tells me :witch IOS to install ?
Instead of IP Base, you need IP Security feature set.
Oh yes.
Fastest and easiest method is to eject the CF and use a card reader to copy the correct IOS into the CF.
Hi Nico,
You need to upgrade to c1841-advsecurityk9-mz.124-24.T3.bin in order to get firewall services.
Regarding for correct price details please contact any Cisco dealer or support contracts.\
Please see the below link for step by step IOS upgradation procedure for 1841 router.
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/prod_bulletin0900aecd806571a6.pdf
Go to the page 2 "Procedure 2—Upgrade Cisco IOS Software"
Please rate the helpfull posts.
Naidu.
Leo Laohoo
Oh yes.
Hi Nico,
Naidu.
