Port Lights on a 3750g
magibson2
I am trying to light up every port light on a 3750g.  There is not anything plugged into them and I would like to know (just for fun) is there a way to make every port light 1 - 48 turn on using a command?
Reza Sharifi
In order to see the light, you need to connect devices to each port or loop ports together using copper cables
How would that be done sir?
AFAIK the only way you will see all the lights on is when the switch boots, then there is a self check done and part of that is to light up all green and all amber lights.
good luck
