Upgrade Cisco 6500 (SUP720/MSFC3)
This is my first post, I hope not to repeat with another previous post.
I want to upgrade a pair of Cisco Catalyst 6500, these have this software: s72033-jk9s-mz.122-18.SXD5.bin, to change a 12.2 (18) SXF or 12.2 (33) SXI
The problem is that I'm sure the modules compatibility with every version of IOS. Especially the WLSM and FWM. Can you help me?
Thanks for everything.
Attached some commands with information from the 6500:
SHOW VERSION
IOS (tm) s72033_rp Software (s72033_rp-JK9S-M), Version 12.2(18)SXD5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 13-May-05 18:46 by ssearch
Image text-base: 0x4002100C, data-base: 0x42698000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-JK9S-M), Version 12.2(18)SXD5, RELEASE SOFTWARE (fc3)
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19 (SP by power-on)
System restarted at 18:40:17 GMT1 Thu Dec 1 2011
System image file is "sup-bootflash:s72033-jk9s-mz.122-18.SXD5.bin"
cisco WS-C6509-E (R7000) processor (revision 1.2) with 458720K/65536K bytes of memory.
Processor board ID SMG0925N3ND
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
39 Virtual Ethernet/IEEE 802.3  interface(s)
153 Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
SHOW MODULE
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 1000mb SFP              WS-X6748-SFP       SAL09264D1U
  2    6  Firewall Module                        WS-SVC-FWM-1       SAD0930053E
  4   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1133XGTJ
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL09211F9C
  8    1  Wireless LAN Service Module            WS-SVC-WLAN-1-K9   SAD091705PR
  9   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL09253YYG
Mod Sub-Module                  Model              Serial        Hw     Status
  1 Centralized Forwarding Card WS-F6700-CFC       SAL09253JC8   2.0    Ok
  4 Centralized Forwarding Card WS-F6700-CFC       SAL1133XG7T   3.1    Ok
  5 Policy Feature Card 3       WS-F6K-PFC3B       SAD09110D03   2.0    Ok
  5 MSFC3 Daughterboard         WS-SUP720          SAL092019WE   2.3    Ok
  9 Centralized Forwarding Card WS-F6700-CFC       SAL09253JCA   2.0    Ok
Leo Laohoo
Thanks for being considerate.
Ok, here comes the business end:
I hate to be the bearer of bad news, but WS-SVC-WLAN-1-K9 is not supported in SXH and higher.
WS-SVC-FWM-1 is still supported from 12.2(14)SX1 and higher.   Read more from here.
Hi leolaohoo,
   Yes, are bad news, but I was sure I could not install an IOS very new.
   My fear is the compatibility of the two modules (FWSM and WLSM).
   Reading other post I've seen that the best option is the IOS 12.2 (18) SXF, as indicated in this thread:
https://supportforums.cisco.com/thread/141265
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/release/notes/hardware.html#wp2566026
   Thanks again, the next stage in the upgrade of these two modules.
