Upgrade Cisco6807-SUP-2T and Cisco6807-SUP-6T
marzi
Hi all
I have to do an IOS upgrade to these platform
model old release new release (suggested)
C6807-XL-S6T-BUN 15.5(1)SY1 15.5.1-SY10
C6807-XL-S6T-BUN 15.4(1)SY1 15.5.1-SY10
C6807-XL-S6T-BUN 15.4(1)SY2 15.5.1-SY10
C6807-XL-S6T-BUN 15.3(1)SY 15.5.1-SY10
C6807-XL-S6T-BUN 15.5(1)SY8 15.5.1-SY10
C6807-XL-S2T-BUN 15.2(1)SY1a 15.5.1-SY10
I haven't find an upgrade procedure in the release note suggested, please is there anyone that could tell me where find how to do ?
Thank's in advance
FM
3 Accepted Solutions
@marzi wrote:
!3 verify
verify/md5 Following I describe all the step needed for the uppgrade :
verify /md5 bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin 72065376fd1203415f7bdba8847650e3
verify /md5 slavebootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin 72065376fd1203415f7bdba8847650e3
@marzi wrote:
!7. Reload the entire chassis, this operation will reload the two supervisor too
!Note: It is important to reload both the supervisor because the IOS must be the same version
vss1#redundancy reload shelf
Reload the entire shelf [confirm]
Preparing to reload this shelf
*Jul  4 06:18:55.308: %RF-5-RF_RELOAD: Shelf reload. Reason: Reload Shelf CLI
*Jul  4 06:18:57.020: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Shelf CLI.
Save the config.
Export the config to an external device.
Reboot using the command
reload
.   Do not use the
redundancy
command to reboot both units.
@marzi wrote:
1) If something should goes wrong, pointing again to the old image could be a solution ?
Correct.  Fall back to the old IOS.  This should be in the boot variable statement.
conf t
 boot system flash bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin
 boot system flash bootdisk:s2t54-adventerprisek9-mz.SPA.152-1.SY1a.bin
end
wr
@marzi wrote:
2) I think that further attention I must pay for an eventually upgrade of the rommon too, are you agree ?
On a 6807 & 6880, I never upgrade the ROMMON.
8 Replies 8
Leo Laohoo
Please read the Release Notes very, very carefully because the destination is 15.5(1)SY train.  Special care to "read between the lines" because the BU has deliberately hidden the information about manual FPGA.  The vital information about "what are the affected line cards" have been removed and the hidden command to perform the FPGA upgrade is not incorporated into the Release Notes documentation and instead, a hyperlink to some other document.
If the FPGA upgrade to the affected line card(s) are not performed, the affected line card(s) will stay down.
It is of utmost importance that someone read and, most importantly, understand Performing FPGA Upgrade.  Make sure to have console access to the Sup2T and Sup6T so can be possible to perform the manual FPGA upgrade.
Word of Warning:
Do not, under any circumstance, make any attempts to upgrade the IOS using ISSU, FSU/eFSU/xFSU.
Hi Leo
I've read the link about upgrading FPGA, and I could be in the condition to do an upgrade,
forgive my trivial question but about the following command:
For VSS case:
Device# upgrade winters-flash switch switch-number slot slot-number bundled-image gold
slot nomber is referred to the line card module ?
for example:
vss1#sh inventory
NAME: "Chassis 1 1", DESCR: "Chassis 1 C6800-32P10G DCEF2T 8 port 40GE / 32 port 10GE Rev. 1.2"
PID: C6800-32P10G , VID: V01, SN: SALXXXXXXXXX
NAME: "Chassis 2 1", DESCR: "Chassis 2 C6800-32P10G DCEF2T 8 port 40GE / 32 port 10GE Rev. 1.2"
PID: C6800-32P10G , VID: V01, SN: SALYYYYYYYYY
the command will be
vss1# upgrade winters-flash switch 1 slot 1 bundled-image gold
vss1# upgrade winters-flash switch 2 slot 1 bundled-image gold
Is it correct ?
FM
Yes, the syntax is correct.
Hi Leo
Following I describe all the step needed for the uppgrade which do not fall within ISSU, FSU/eFSU/xFSU cases (I suppose):
!1. Copy the new image into the active supervisor inside the
bootdisk
vss1#copy tftp:s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin bootdisk:
!2. Copy the new image into the standby supervisor inside the
slavebootdisk
vss1 #copy bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin slavebootdisk:
!3 verify
!4. Check that IOS is correctly copied inside both supervisor
vss1#dir bootdisk:
vss1#dir slavebootdisk:
!4. Setting the boot.
vss1 #config terminal
vss1 (config ) #boot system flash bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin
!5. Save the configuration, automatically the conf. will be saved into standby supervisors.
vss1 #copy running-config startup-config
Destination filename [startup-config]?
Building configuration...
Compressed configuration from 14022 bytes to 5201 bytes[OK]
!6. Chek the boot system with the correct IOS
vss1#show bootvar
BOOT variable = bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin bootdisk,1;
CONFIG_FILE variable =
BOOTLDR variable =
Standby BOOT variable = bootdisk:s6t64-adventerprisek9-mz.SPA.155-1.SY10.bin bootdisk,1;
Standby CONFIG_FILE variable =
Standby BOOTLDR variable =
Standby Configuration register is 0x2102
!8. Verify VSS Switch Redundancy                                              
!   After that the two chassis coming up verify that the two supervisor have the same IOS version
vss1#show switch virtual redundancy
Now, I've got two question more :
   for example :  boot system flash bootdisk:/s2t54-adventerprisek9-mz.SPA.152-1.SY1a.bin
Thanks for all support
FM
@marzi wrote:
!3 verify
Save the config.
reload
.   Do not use the
redundancy
conf t
end
wr
