Upgrade DRAM on Cisco ISR 4451
I want to ask about upgrade DRAM on Cisco ISR 4451, is it possible if I want to upgrade the DRAM (before 4G) to 16G? Is there any association with Flash Memory? Because I have a note when I want to upgrade the DRAM.
Thanks and Regards,
Bella
Hi @bella.nurhasanah
According to Cisco doc, you can upgrade to 8 GB:
Platform
Part number
Description
Cisco 4400 Series Routers (4451 and 4431)
MEM-4400-2G=
2G DRAM (1 DIMM) for Cisco ISR 4400, Control Plane or Data Plane, Spare
MEM-4400-4G=
4G DRAM (1 DIMM) for Cisco ISR 4400, Spare
MEM-4400-8G=
8G DRAM (1 DIMM) for Cisco ISR 4400, Spare
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/guide-c07-732797.html
-If I helped you somehow, please, rate it as useful.-
So can you just buy the memory from Newegg or such? I don't want to cause a problem with my SmartNet coverage, but I don't see an easy path to buying the DRAM.
