08-28-2018 10:20 AM - edited 03-05-2019 10:53 AM
I have some locations connected by a L3 network and 897 routers.
Anyone know if it is possible to create a L2 domain across this setup.
VXLAN/EoMPLS or something similar
08-28-2018 10:27 AM
check if your routers support the below:
L2 Bridging Across an L3 Network Configuration Example
08-28-2018 10:43 AM
08-28-2018 11:06 AM
indeed L2TP is point-to-point only, you cannot use it for multipoint topologies.
There is LISP (Cisco Locator/ID Separation Protocol), see the link below for a config example:
