upgrade of 7204VXR with NPE-G1
aoshea
Dear support,
I am after some advice on the upgrade of two of our 7204VXR routers. These are our perimeter BGP / OSPF routers.
They are both running c7200-p-mz.123-9.bin
Currently we have 2 x 7204VXR’s each with;
NPE400 (256 MB RAM)
I/O controller (think C7200-I/O-GE+E)
2 x 1 port Fast Ethernet card (PA-1TX is this compatible with the NPE-G1)
1 x 8 port Ethernet card
We are currently looking at implementing gigabit connectivity both externally and internally and looking to upgrade the NPE from the NPE400 to the new NPE-G1.
First question;
Is there any benefit in keeping the I/O as we are currently using the GE and FE ports, or is the performance affected?
Second question;
Any gotcha’s should be aware about the upgrade … like ports being renumbered or additional contention on the ports?
Third question;
Any additional advice that may be relevant.
Thank you in advance for your assistance.
Regards, Adrian.
pkhatri
Level 11
Level 11
Quoting from CCO:
"Because the NPE-G1 has a console port and an auxiliary port, and handles the other functionality of the I/O controller, the need for an I/O controller is eliminated. However, an I/O controller can still be used. If an I/O controller is detected in the I/O controller slot, I/O controller functionality defaults to the I/O controller (with the exception of Non-volatile Random Access Memory [NVRAM] and boot flash). The console and auxiliary ports of the NPE-G1 are then disabled."
Speaking from my experience with this and in answer to your questions:
1. The benefit is that you get extra ports :-)
2. While I have not used a C7200-I/O-GE+E, I would imagine that the GE port appears as Gig0/0. The GigE ports on the NPE-G1 are numbered starting at Gig0/1.. Therefore, no re-numbering should occur.
Gotchas - just be mindful of which AUX/Console ports will be active (as mentioned above).
Hope that helps - pls rate the post if it does.
Paresh.
Many thanks for your assistance.
Regards, Adrian
