Upgrade path from 12.4 to 15.1 IOS
Hi all...
I need advice from you guys and gurus here
I finally can upgrade my 1841 routes from 12.4 to the latest 15.1 IOS. Can someone please instruct me about upgrade path , do I need to modify config file and provide me with upgrade instruction link or something like that ?
Thank you in advance
Best Regards
Neeraj Arora
Level 3
Level 3
Config file does not need any modification for IOS upgrade, just make sure you keep the backup of the config and the old IOS before reloading the router with the new 15.1 IOS
This document should be able to assist you with the step by step procedure for upgrading the IOS on routers:
http://www.cisco.com/en/US/products/ps5855/products_tech_note09186a00801fc986.shtml
hope it helps.
Neeraj
Leo Laohoo
Make sure you have the right amount of DRAM and flash.
