Upgrading IOS for Cisco 1001-x
krisvamcee
Hi all,
I am trying to upgrade the IOS for Cisco 1001-x from 03.x to Everest 16.6.4 and I believe I need to upgrade the ROMMON version as well, but however I don't see ROMMON software available for 16.6 as it has to be the same IOS if I am upgrading to Everest 16.6.4, so in that case I can update to only Denali 16.3.6 as I can see ROMMON version 16.3 for Denali?
Or can I upgrade to Everest 16.6.4 with ROMMON software 16.3?
Could somebody please advise?
Vamsi
19 Replies 19
Leo Laohoo
Find the latest ROMmon, version 16.3(2r), and upgrade to that.
Thanks Leo, yeah I did see the latest ROMMON is 16.3, but I would like to upgrade to Everest IOS which is 16.6.4.
Are you saying that ROMmon, version 16.3(2r) is supported for Everest 16.6.4?
Vamsi
Yes
Thanks Leo, is there any link or on Cisco website where it says it supports ROMMON 16.3 for Everest 16.6.4 as I couldn't find one.
Vamsi
There is no "rule" that the ROMmon and the IOS should "match".
My recommendation is to upgrade the ROMmon when one is upgrading the IOS.
It's as Leo notes, ROMMON versions and IOS versions don't need to match, and rarely do.
Possibly OP is thinking of some older Cisco devices that used to support a mini-boot IOS image, that often could be found with the same version number as the main IOS.
As to OP's question about what IOS versions a ROMMON version supports, if there are such limitations, they should be noted in the release notes for the ROMMON. Generally the latest ROMMON version will support all IOS versions at the time of its release, and for some time after. If some IOS version needs a certain version of ROMMON, that should be noted in its IOS release notes.
Thanks Joseph.
One last question, what if the below version fails if I upgrade to 16.3 from 15.4. Does the ROMMON version fail back to 15.4 automatically? I know it will work but just want to make sure.
Router##upgrade rom-monitor filename bootflash:asr1000-rommon.163-2r.pkg all
If the upgrade fails, I believe ROMMON will boot either from the other region (there's usually two) or will use the built-in ROMMON. Like Leo, I don't recall having a ROMMON upgrade fail.
Thanks a lot Leo.
Kris
If the ROMmon fails to upgrade then it will fail to upgrade and the old version will remain.
I have upgraded many, many ROMmons and I've never had one that has failed.
Thanks Leo.
And if I upgraded successfully ROMMON to 16.3 and if the new IOS (Everest 16.6.4) fails to upgrade and it will revert to 3.12. I hope the ROMMON will be on 16.3 and the IOS will be on 3.12, and it won't be a problem.
Vamsi
ROMmon and IOS are two separate files. One can't/won't influence or affect the other.
Thanks Leo
Hi Leo, Joseph
Apparently the IOS upgrade didn't work, even the ROMMON is back to 15.4 and IOS is back to 3.12. Any thoughts what could be the reason. I have attached some logs.
Kris
