Upgrading IOS major revision on an older 2811 router
After buying a new VWIC2 card, I've found out I need to update my IOS for it to be recognized.  My current "sh ver":
==========8<---------------------------------
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.3(11)T3, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 26-Jan-05 02:49 by pwade
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
ROM: Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.3(8)T5, RELEASE SOFTWARE (fc2)
pl5-voice-gw uptime is 1 hour, 3 minutes
System restarted at 09:12:07 CST Fri Aug 6 2010
System image file is "flash:c2800nm-spservicesk9-mz.123-11.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FHK0848F0N7
2 FastEthernet interfaces
18 Serial interfaces
2 Channelized T1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62592K bytes of ATA CompactFlash (Read/Write)
=============8<----------------------------
Since 12.3 is not supported anymore, I need to switch to a 12.4 image.  What I'm looking at is c2800nm-spservicesk9-mz.12.4-24.T3.  Is there anything fancy to upgrading a major revision like this, beyond normal caution of a standard upgrade, or will this completely change items so that my current config will need to be reworked?
Thanks...
Jerry Ye
No you should be fine. Save your original config and image in TFTP as backup.
jerry
Jerry Ye
jerry
Great, thanks!
